Question about Garden
1989 Murray Riding Mower deck belt broke. I
1989 Murray Riding Mower deck belt broke. I bought a replacement. How do I put it on?
Thank you!
  • 24 Answers
SOURCE: murray riding lawnmower motion belt routing
I need your model # took look it up , I am a Murray dealer.
The thing to rember there are two kinds of idler pulleys flat idlers that ride on the back side of belts and v pulleys that ride inside the belt . wont be back to the shop until the feb 10.
good luck
Posted on Feb 08, 2009
  • 4 Answers
SOURCE: drive belt broke murray riding mower how do i put one in?
yes the drive belt is the bottom one it looks hard but is really simple the main thing is you have to look rite above the left back tire and remove two 5/16 bolts with an 1/2 in wrench to in stall drive belt the you install other belts
Posted on Aug 08, 2009
mowerman1857
  • 389 Answers
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Posted on Sep 30, 2009
mowerman1857
  • 389 Answers
SOURCE: how to adjust the mower deck on my murray rider,
Park the tractor on a firm, level surface. . .
At the lower end of the lift/lower travel slot, there should be a plastic cover which you pop up so that your blade lift handle goes all the way down (it should say something about blade level on there somewhere. . . . .
After you have the handle in this position, look at the front lift arms of the mower deck and find the 2 large wing nuts, one on each side. . . . .
Loosen these while the deck is down and then retighten them Your deck is now level and will lift to its highest recommended position when you raise the lever
Posted on Oct 11, 2009
  • 252 Answers
SOURCE: need belt diagram for murray riding mower 17.5hp
here is website for parts diagrams
http://www.partstree.com/parts/?lc=murray&mh=8
enter / select your murray model fron the list and then go to approriate sub section
general belt layout should be shown with realative parts along with deck
just be sure to select correct model and size deck , this info should be on your mower somwhere most likly on a white sticker
cherrs hope it helps paul
Posted on Aug 02, 2010
How does belt go back on for mower deck
Gary, Belt diagrams can usually be found on the Deck it self or in your manual. If you do not have either check the links below or Google search your make and model# manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Service Mower
Murray Belt Graphics
Craftsman Riding Mower Deck Belt Diagram
lawn tractor deck Belt diagrams Google Search
May 29, 2016 | Garden
Will an older 42 inch murray riding lawn mower deck interchange with an older rally riding lawn mower deck ?
Mower decks are very specific to the tractor. Unless it was the same manufactured mower, and just branded differently, then not likely! Belts are your next problem as even an inch longer or shorter will cause problems.
May 07, 2016 | Murray Garden
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
30" Murray riding mower drive belt diagram
Here's a link to your belt diagram,just click on picture to in large. motion drive belt came off 10 hp 30 deck mower Murray Riding Mower
Aug 21, 2014 | Garden
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
www.murray.com
Sep 30, 2009 | Garden
Drive belt broke murray riding mower how do i put one in?
Aug 08, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
I have a 1995 murray lawntractor model#42816B.The deck belt broke and need a routing diagram on which the way the belt goes on.Bought new idler and belt.The belt length is 35x75a.Is this the correct size?
Have you tried going to www.murray.com and then find a dealer. Call them and ask if it is right belt. If you have the old belt there should be number stamped on it. If you have the number and you can't find a belt try a mower repair shop and they can cross ref it and get new number if it has been changed.
Then when you put the new belt on make sure you have the right belt and then it should be fairly easy to route the belt if you put the back of the belt (flat side) up against the larger in height idler pulleys and the smaller (v) in the smaller pulleys. The belt should be snug when on properly.
let me know if this helps.
Thanks
roundo4
Jul 31, 2009 | Garden
Deck belt diagram
Go to ... http://www.partstree.com/parts/ Then click on Cub Cadet, enter the model number on the left that is under the seat and all the different diagrams are there. Click on Mower Deck.
Jun 29, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
123 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
