Question about LG 42LG30 42 in. LCD HDTV
There is a flashing message on teh screen that says, " This function is not available now."
The answer i viewed on another site was that the mainboard was fried and a cost of over $400.to replace the board(not counting labor). Life sure is good...thanks for 3 years use of a 37 inch LCD monitor.
Posted on May 27, 2010
I get this message when I've selected an input such as 'HDMI1' or one of the component inputs and try to change channels with the TV remote instead of the cable remote.
Posted on May 01, 2010
Keep getting message the process android has stopped but if i click ok teh screen goes black and comes back with same message and wont allow me to click on anthing else
Put simply, there isn't any recovering from this without flashing your tablet back to stock. The error you're receiving is that Android itself is broken, kinda like if you delete System32 from Windows.
If you have the technical know-how, look up how to flash a new ROM for your tablet. If you don't, look up how to factory data reset your tablet. If it's still under warranty, now would be a good time to call in that warranty.
Nov 02, 2015 | Tablets & eReaders
How do I find and reinstall WiFi adapter
If you know the name of the adapter manufacturer the brand and model # you may be able to go to the manufacturer's web site directly and download and install the file. Setparately if teh "repari" function from teh origianl installation is not working, you may need to do a full reinstall. You will probably need teh key code for teh OS to successfully complete a full reinstall.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Dec 23, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Message Fan Check visible then 'protection' then powers off
my system keeps turning its self off then the standy keeps flashing...does any1 no why???thanks
Nov 20, 2011 | Audio Players & Recorders
We have an Aficio 2238C that is giving an error message upon startup. It says functional problem, turn off unit and turn back on, etc.... error number SC471.\r\nI have tried the "yellow...
Probably this happened after a paper jam??? Yes???
This error is related to the Tranasfer Unit.
This SC 471 can be cleared by removing and re-installing teh Transfer Unit.
If this doent work you probably have to replace a mylar. For that i advise you to call a technician
Apr 07, 2011 | Ricoh Aficio 2228C Copier
How do you delete a text message
Open teh messages application, locate the desired message and touch & hold the message on your screen. You will now see a pop up menu with teh delete option.
Jan 17, 2011 | HTC Wildfire Cell Phone
My son has a TI-84 Plus calculator and it is completely frozen. There is a message on the screen that reads " RAM cleared". Below that message it says "Press ALPHA F1-F4 to locate shortcut menus" but it...
The calculator OS has been upgraded to the version 2.53 MP.
For this version, whenever you remove batteries (or replace them) and turn calculator ON, you are reminded to Press [ALPHA][F1-F4] to locate Shortcuts Menu.
The calculator also asks the user to press either
[1:Do NOT show Again]
[2:Continue].
Here is what these cryptic messages mean.
Certain functions implemented on the new OS are available by pressing the [ALPHA] key followed by F1, F2, F3 or F4.
Since you may forget how to get to them, the calculator gently reminds you that there are other functions accessed only by pressing the [ALPHA] key.
It also gives you the option to flash the reminder every time the calculator memory is reset (CONTINUE) or NOT to SHOW the REMINDER again.
Usually after the RAM cleared message, press [2:Continue] or any other key but [1: ] to keep being reminded how to access the new functions.
Once a key is pressed the screen is cleared and you have the solid blinking cursor.
Oct 06, 2010 | Texas Instruments TI-84 Plus Calculator
On/Off Button on TV not working, constant flashing message
www.lg.com/us/tv-audio-video/pdf/47LG50_spec_sheet.pdf
http://elektrotanya.com/lg_lcd_tv_la84a_mfl41370007_47lg50-ua.pdf/download.html
Above user manual top, below is your service manual, perform the troubleshooting procedures and you should be able to localise your problem.
May 13, 2010 | LG 47LG50 47 in. LCD HDTV
I am trying to set the self timer, can anyone help me with that?
Self timer is not available in AUTO mode.
Please check the other options ( As I do not remember the other right now)
Select the other options available (eg: Tv,Av etc) and hit function key and scroll down.
In the self timer it self you can also mention how many shots you want to take.
Also you can see teh manual. In the last pages it is being under teh section Self timer.
Jun 15, 2009 | Canon PowerShot A520 Digital Camera
My screen is black. Can you help me?
I had a similar problem, but in my case teh screen was not entirely black but the image was very dar, like someone shut of teh lcd backlight, but the photos were coming ok (when checked on the pc). Showed it at repair sho, abd found out that one of the pcb supplying power to the backlight was not working and had to be replace. couldn't do much at home.
Apr 03, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Bang and olufsen BEOTALK 1200
Make sure answer machine function is turned on. Bottom right button.
Make sure an outgoing message is set. Should see a <-> arrow in the display screen. If not, press the <-> button. To record outgoing message... the press the middle button; record out going message; press middle button. Wait a few seconds and you should be set. Hope this helps
Aug 28, 2007 | Bang and Olufsen Beotalk 1200 Digital...
LG 42LG30 42 in. LCD HDTV Logo
355 people viewed this question
