Question about Electrolux 23 in. ESI602 Free-standing Dishwasher
Electrolux esi602 wont work door doesnt lock - Electrolux 23 in. ESI602 Free-standing Dishwasher
2 Suggested Answers
  • 195 Answers
SOURCE: My Electrolux ESI602 dishwasher has just started leaving rust spots on all my cutlery & a white residue on the inside of the dishwasher (like limescale). Any idea what the problem is ?
This is a something i see all the time always use the better dishwasher soap it cost a little more but in the long run it works better, also use less soap then what they say to use , so it will cost you less !
Posted on Dec 02, 2011
There is power to the dryer, but when i hit start, the door doesnt lock and then start? What could be wrong?
That's a great question, friend!
From what you have described your Electrolux dryer is not locking or starting when you hit the start button. It sounds like a potential issue with your door latch or main control panel. If your door latch is not sensing the door is closed and locked it will not start your washer cycle. Also, if your control panel is not registering the door is closed it will not lock and start the cycle. I suggest you reach out to a professional for proper repairs to be completed. If you do not have a professional contact you can visit your manufacturer's website for additional assistance. I hope this is helpful information to you. -Matt
Mar 23, 2015 | Electrolux Dryers
Electrolux oven wont work after cleaning
Hi ja1078063,
I understand you having trouble getting your oven to work after using the self-cleaning mode. Does any part of the oven work? Confirm a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc.
Does "Loc" appear in the display if any button is pushed?
The Oven Lockout feature automatically locks the oven door, prevents most oven controls from being turned ON. Press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked.
Best Regards,
Jan 22, 2014 | Electrolux EW30EW65SS Stainless Steel...
Dec 02, 2011 | Electrolux 23 in. ESI602X Built-in...
ESI 602 dishwasher trips out the mains trip switch after a couple of seconds after turning on any solutions please.
needs looking at.........bad earth can cause trip
also the rear element or stats wire can short against the machine casing.......
cheers
Mar 27, 2011 | Electrolux 23 in. ESI602 Free-standing...
No water entering dishwasher electrolux 602
First is water coming into the location and is the valve to the dishwasher open? Next check if the intake hose is bent or squashed. Release the kink blocking water flow.
There is a filter in the intake hose that can get blocked by debris. Turn off the water (at the supply valve) then disconnect the intake hose. Clean the filter. Reconnect the hose and turn the water back on. Check for leaks.
The manual for the unit is available here: http://kitchen.manualsonline.com/manuals/mfg/electrolux/esi_602.html .
I hope this helps.
Feb 21, 2011 | Electrolux 23 in. ESI602 Free-standing...
Electrolux dishwasher wont lock but still runs, water sprays out of the door
check that the top basket wheels are not broken a rogue wheel in the runner can stop you pushing the top basket in. this stops you closing the door. also that the retainers on the end of the runners are in the right position and not jamming the door action. failing that you will need a new door lock..
Jul 30, 2010 | Electrolux Dishwashers
Main wash pump is working but wont pump out
I guess you have checked the drain pipe outlet etc. if all is clear then the common fault on this wash pump is that the plastic blades on the pump Impeller have broken up.This is a 2 way pump one direction for pumping water to the spray arms and the opposite direction for the drain cycle.The pump will need replacing or you can buy a kit to replace the Impeller blades.To remove pump empty water out of dishwasher and take off plastic panel at rear of unit.Then remove metal plate across back of pump then extract pump and you will see how bad the blades are.
Hope this helps.
May 22, 2010 | Electrolux 23 in. ESI602 Free-standing...
My washing machine door doesnt lock properly
its most likely your door lock if it is malfunctioning the washer will not work
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
Electrolux ESF 662 no water is taken into the machine
Mine did the same thing. Turned out it was leaning back a bit, so I leveled it and now it seems to be working fine.
Mar 08, 2010 | Electrolux 23 in. ESI602 Free-standing...
Open Questions:
Electrolux 23 in. ESI602 Free-standing Dishwasher Logo
46 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
