Question about Western Digital My Book Home Edition 500 GB USB Hard Drive
My WD external HDD is not registering.
Hi, my WD is not registering on the computer. Do they have a lock mechanism?
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes
USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a
USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all
USB cables are equal even though they should be)
3. Do not connect through an external
USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the
USB "Safely Remove Hardware" option. If you don’t do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to check the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. Ensure that you have set removable drives for "quick removal" or that you use the "Safely Remove Hardware" option often shown on the lower toolbar. It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! And knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click of Death"
On rare occasions it is possible that the PSU for the drive can also fail.
This is quite rare on the better quality drives but is still a possibility.
if this does happen it may be possible that the PSU supplies enough power to light the LED on the drive but not enough for the drive itself to operate..
In those instances any commonly available replacement with BOTH the same voltage and current rating will work
eg. 5V 700mA as may be written on a drive or the instruction / specification sheet that came with it.
NEVER use less than the req voltage and never use less than the req current although you can use a larger rated current. eg. 5V 1000mA would be fine and last longer than the original PSU.
If the drive does not show up in your hardware lists then using software of any description to try recover files is a total waste of time.
If the drive is still under warranty or you don't mind opening it up it is not uncommon for the connection between the interface board and drive to have worked loose esp. if the drive has been moved a lot.
In those circumstances opening the drive enclosure and removing the connection and then re-connection can also fix quite a few issues.
Hope this gives you the information you need
Posted on May 01, 2010
  • 1 more comment
  • Project NOMAD
    Project NOMAD May 07, 2010
    Did this help at all ?
  • Project NOMAD
    Project NOMAD Nov 03, 2011
    online 4u adipex advicer baccarrat blackjack bllogspot booker byob car-rental-e-site car-rentals-e-site carisoprodol casino casinos chatroom cialis coolcoolhu coolhu credit-card-debt credit-report-4u cwas cyclen cyclobenzaprine dating-e-site day-trading debt-consolidation debt-consolidation-consultant discreetordering duty-free dutyfree equityloans fioricet flowers-leading-site freenet-shopping freenet gambling- hair-loss health-insurancedeals-4u homeequityloans homefinance holdem holdempoker holdemsoftware holdemtexasturbowilson hotel-dealse-site hotele-site hotelse-site ****** insurance-quotesdeals-4u insurancedeals-4u jrcreations levitra macinstruct mortgage-4-u mortgagequotes online-gambling onlinegambling-4u ottawavalleyag ownsthis palm-texas-holdem-game paxil ***** pharmacy phentermine poker-chip poze ***** rental-car-e-site ringtones roulette shemale shoes slot-machine texas-holdem thorcarlson top-site top-e-site tramadol trim-spa ultram valeofglamorganconservatives viagra vioxx xanax zolus
  • The answers by Project Nomad / bob_computer are to be considered copyright 2011 and property of
    R. Humpleby
    Use without prior "written permission" is no longer allowed.
    This property is no longer shared with Fixya and its associates / affiliates
    Reason. account termination.
External wd hdd driver letter not seen in IBM x3200 server, but listing in drives to be removed
go to control panel -- administraive tools -- computer management -- disk management
Find the drive and right click on it. select to change the drive letter
Apr 13, 2012 | IBM System x3200 M2 Server
Hi, Brand : Imation Model : Apollo M250 Capacity
Hi, The hard drive Apollo M250 does not have any locking mechanism. It only has backup software. If your computer does not detect the HDD, it only means that the HDD is already broken.
Aug 15, 2011 | Computers & Internet
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
When I plug my 320G WD Elements there is no WD icon on my windows or my computer window. thanks
Have you used this HDD before?, it this is the first time?
Sometimes you have to install the WD Smartware Software. In the case of the 320G, which are the first HDD released, The computer should detect them automatically.
Try with another USB port. Do not use a USB multiport because it won't power the HD.
If it doesn't work on your computer, try it on another one. This way you can discard the possibility that the HDD is damaged.
God BLess You!!!
Feb 14, 2011 | Western Digital Passport 320GB External...
My WD External Passport HDD is not accessible. The hard drive is shown in My Computer, but everything hungs up on trying to access.
Hi.
You have to install WD Smartware, which is located on another drive.
THen you will have access to it.
Otherwise the drive is damaged.
God Bless You!
Feb 05, 2011 | Western Digital 1TB My Passport Essential...
Trying to open my wd passport external drve, with my compaq presario 700 laptop ,it will not open it
if your external hdd works fine with other computers, then the USB ports on your motherboard does not provide sufficient power to start your external HDD you may use a dual usb cable like this
http://www.cooldrives.com/usb-power-cable-mini-b.html
if your external hdd works the same with other computers then it may be one of two reasons 1- the usb controller inside the external cage
2- physical problem on the hdd it self
Jan 20, 2010 | Compaq Presario 700 470024-192 Notebook
I put my laptop cord in WD book andnow does not work to
Sounds like you fried the circuit in the WD. Hopefully it's not the HDD electronics but only the power-connector electronics.
You could try to disconnect and remove the HDD from the WD book and hook it up to a computer 'internally'. If it's recognized, the HDD itself is probably fine and you should be able to rescue the data.
If not, the HDD electronics are probably fried too, meaning that for data recovery, the electronics on the HDD have to be replaced, which requires a "donor HDD" (of exact the same type). That would be a very expensive data recovery (in both parts and labor).
Aug 24, 2009 | Western Digital External USB 2.0 80 GB...
Problem with WD EXT Network HDD (1TB)
Have you set up the drive as shared on your network?
Apr 15, 2009 | Western Digital My Book Essential 1TB...
WD External HDD Drivers For Win 98
I dont think the Win 98 has a plug and play option. You may need to search for device drivers for your external HDD which may not be easily available
Feb 01, 2009 | Computers & Internet
WD 120 GB 2.5" hdd not listed in my computer
I HAVE MY PROPERIETRY SOFTWARE WHICH I USE TO FORMAT ANY DISK OF ANY TYPE... AND MAKE ANY TYPE OF PARTITIONS LIKE ALL IN ONE PARTITIONING AND DISK MANAGMENT.
I HAVE STILL NOT REGISTERED AND TRADE MARKED IT. BUT I AM SUCCESFUL IN MY PRACTICE ON VARIUOS HARD DISK DISCOVERIES AND RECOVERIES .EVEN I CAN DO A FULL ZERO LEVEL FORMAT TO ANY HD.
CATCH ME AND REQUEST FIXYA TO ALLOW YOU TO SEND YOUR HDD OR ANY TYPE OF STORAGE MEDIA FOR RECOVERY AND SOLUTIONS. +0+9+3+2+1+1+0+1+7+1+7
Apr 17, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Western Digital My Book Home Edition 500 GB USB Hard Drive Logo
213 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
