Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
How do i adjust the shower head to full hot - Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
  • 349 Answers
Take handle off and it is a dial that restricts water to safe temp. You can adjust temp that way.
Posted on May 05, 2010
2 Suggested Answers
hessmar
  • 5 Answers
SOURCE: hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Posted on Dec 04, 2008
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
How to adjust hot water on shower
Turn on the hot water first. Wait for it to warm up, then turn on the cold water until the mix is the temperature you want. I recommend doing it before you engage the shower diverter to divert the water to come out the shower head.
Sep 19, 2014 | Home
Push Pull Shower Valve also off in middle position
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Feb 09, 2012 | Moen Home
I do not have enough hot water from my shower head. I have plenty of hot water in my bathroom and kitchen sink. What can I do to remedy the problem?
the problem is the hot/cold mix is set wrong ---
remove the water control handle to expose the mix valve -- you should see a small set screw that will either increase or decrease the travel of the hot water valve. --- sometimes instead of a set screw there is a little pop off plastic set ring,, pop off and set to a more advanced travel.
this will increase the amount of hot water that flows to the shower head and the bath tap.
c...
Jan 20, 2011 | Grohe Freehander Adjustable Shower Head...
I have to turn my shower to full temperature to get any heat out of it but when its on full the pressure is just trickle. I used to have it on number 5 but now number 5 just gives freezing cold water - any...
You have a blockage of the hot water coming to your shower head, or a blockage in the supply line coming to the shower head.
Be careful of the hot water in this procedure below.
Remove the head and try to clear the blockage from the head, as you have the shower head removed try to turn on the hot water to make sure you are getting a full stream of hot water to the shower head, if you do have a full stream coming to the shower head then the blockage is in the supply line coming to the shower head.
Please rate me
Dec 10, 2010 | Home
No hot water comes out of shower just cold comes out even when turned to hot, sink 2 feet away has hot water
The problem more tha likely lies within the shower valve body. Possibly the shower head has an accumulation of deposits clogging up the holes but that would not affect the hot water supply only. You might try removing the shower head and turning on the hot water. If you get hot, immerse the head in Limeaway for a hour or two and replace it, or install a new head. If you still do not get hot water, the shower valve needs attention. The cartridge inside the valve body will likely need replacing or at the least cleaning (Limeaway), replacing rubber seals and use plenty of silicone grease before re-assembly.
Oct 26, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
Fluctuating temperature now got un bearable, ive de scaled shower head totally and cleaned filter !!!!!!!
Test: take the shower head off, then run water. If the water can be adjusted to the desired level (hot/cold mix), then the problem is probably in the shower head. Contact the manufacturer of the shower head. If you cannot maintain a good mix, the problem may be in the valve behind the wall or a total house pressure problem---time to get out your wallet and call a plumber.
Apr 16, 2010 | Home
No hot water coming through the shower system, though hot water comes through the pipe without system attached
When you adjust the dial to mix the hot and cold for your desired liking, it goes into a mixing chamber before going to the shower head, im asumming your issue is within the mixing chamber.
Nov 05, 2009 | Hansgrohe Shower 26101 Pharo Prestige...
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
453 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
