Question about Brother LS-2125 Mechanical Sewing Machine
How do you get to the bobbin? I can't find the manual. .
    Genius:
  • 1,116 Answers
Download free manual here - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=LS2125
Slide the front left section of the sewing machine bed to the left.
Open the door.
Posted on May 01, 2010
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
Sewingpartsonline.com has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), http://www.sewingpartsonline.com/viking-250-sewing-machine-parts.aspx . The direct link to the manual is http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/5bc6115484660075c12575d2003f80e3/ecf97dd171581582852575ed00755e7a/$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
How to thread the bobbin of a singer 90s
First make sure that the needle is fully up (use the hand-wheel). Move the bobbin cover release button to the right and lift the bobbin cover out of the way. Remove the current bobbin, if needed. Hold the new, full bobbin so that the thread comes off the bobbin counter-clockwise when you pull the thread. Place the bobbin into the bobbin case. Pull the thread through the slot near the bottom of the case and to the left. Place a finger on top of the bobbin. Next bring the thread left further towards the back of the bobbin case until it stops in the second slot (near the 8 o'clock position if you compare the position to a 12-hour analog clock). Pull the thread back through the groove in the cover plate until it is cut by the thread cutter at the top left of the cover plate. (The thread will turn a "corner" to the cutter.) Replace the bobbin cover.
Singer has the manual for most of their sewing machines here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 90S is http://www.singerco.com/uploads/download/26e7243ab52aaed42904377fea7b090541eb0c9b.pdf . See pages 16-17 (page 18 in the PDF for the English description) and pictures that may be better than the verbal description.
I hope this helps.
Dec 23, 2016 | Singer Sewing Machines
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
Singer touch sew 645
Singer website has a plethora of manuals to download, http://www.singerco.com/accessories/instruction-manuals is the link, your manual is there for $15. If the bobbin thread is knotting up in the bobbin then I'd say you need to rewind a fresh bobbin and make sure it is smooth with even tension as it goes onto the bobbin. If your bobbin thread looks a bit chunky and uneven, then you won't get good results from it. Also, check that you are putting the bobbin into the bobbin case the right way, the thread needs to come off the bobbin and make a reverse direction into the tension spring (assuming yours is a removeable bobbin case, not top loading)
Oct 11, 2013 | Sewing Machines
Bobbin thread keeps breaking
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
if you don't have a manual, here is a link for a free manual
http://www.singerco.com/uploads/download/1295_3270.pdf
Dec 21, 2012 | Singer 3343 Mechanical Sewing Machine
I have lost the manual and i dont remember how to thread a bobbin. Pleas help me and thank you!
Juki TL-98Q
Loading the bobbin into the bobbin case:
Snap in the bobbin case latch, and put the bobbin into the bobbin case so that the bobbin runs clockwise.
Passing the thread through the **** of the bobbin case, continue passing it under the thread tension spring, and pull out the thread open end about 10 cm from the bobbin case.
Insert the bobbin case fully into the hook, and close the bobbin case latch.
You can obtain a copy of the manual in pdf format for free at:
http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf
Jul 29, 2010 | Juki TL-98Q
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
Bobbin not threaded correctly, no manual to show me how
From the manual:
  • Open the hinged cover
  • Pull the bobbin case tab and remove the bobbin case
  • Hold the bobbin case with one hand (I use left). Insert the bobbin so that the thread runs in a clockwise direction (should come up from underneath).
  • Pull the thread through the **** and under the finger.
  • Hold the bobbin case by the hinged latch.
  • Insert it into the shuttle.
Hope this helps. There are pictures in the manual that make it easier to follow.
Mar 27, 2010 | Singer 8280 Mechanical Sewing Machine
Threading and putting the bobbin back in the machine
Most machines have a bobbin case, that removes to place the bobbin inside and then the case goes back into the machiens. However some bobbins just load the bobbin flat from the top. The best place to start is with your machine's manual. If you don't have the machine manual, contact your machine's manufacturer or google "sewing machine manuals" as there are several vendors who sell replacement manuals. One of them is SewUSA.com and they have free threading diagrams on the site,maybe that would help you get started.
Feb 12, 2008 | Brother XL-5130 Mechanical Sewing Machine
How to properly thread the bobbin
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin. NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  3. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  4. Slide bobbin cover back into position.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Sep 21, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Brother LS-2125 Mechanical Sewing Machine Logo
97 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
