Question about Gateway GT5220 PC Desktop
How do i change non preset mode to preset mode on my pc?
  • David Rice
    David Rice May 11, 2010
    What are you trying to reset? The whole compute,r or the appearance of the desktop, or something else?
  • 186 Answers
Everything you change goe;s through control panel
Posted on May 02, 2010
I cant fix the analog of my watch pasnew model PLG_1002AD GRADE A QC 6
Ignore the instructions I found its not as easy as they say first you need to sync the digital and analog to do this press all four buttons at once and hold for 3 secs tho sets the digital clock to 12 Now press mode till you see h-s hold reset till h-s flashes hold the start button in the analog will start moving its slow so be patient set analogue to 12 exactly ignore the minutes that have passed press preset the minute hand will automatically adjust once done press mode go to the main watch screen hold preset use mode to select hours minutes date year month etc and start to change the values keep it on 12 not 24 hour clock set the clock and press preset the analog will now automatically adjust to the time once done you can change to 24 hr mode if you wish
Mar 06, 2015 | Watches
Sony how to change the bass on my sony mex bt3100u stereo
Hello Tom,
You may have to adjust the EQ7 Preset to XPLOD and then listen to the jam. Here are the instructions from the bt3100u manual:
Selecting the sound quality
- EQ7 Preset
You can select an equalizer curve from 7 equalizer curves ("XPLOD," "VOCAL," "EDGE," "CRUISE," "SPACE," "GRAVITY," "CUSTOM" or "OFF").
1 During reception/playback, press the select button.
2 Rotate the control dial until "EQ7 PRESET" appears, then press it.
3 Rotate the control dial until the desired equalizer curve appears, then press it.
4 Press (BACK).
The display returns to normal reception/play mode. To cancel the equalizer curve, repeat the first 2 steps then select "OFF" in step 3.
Tip
The equalizer curve setting can be memorized for each source.
We hope that this helps. If not please return and post how this went.
Nov 24, 2013 | Computers & Internet
Benq lcd monitor
The monitor requires an input before it can decide what the input is.
Nov 05, 2013 | Computers & Internet
How can change none preset mode
Can you rephrase the question?
Dec 24, 2012 | Gateway GT5220 PC Desktop
When turning on the monitor it reads non preset mode
Go to menu and set it to factory default.Thank you.
Sep 16, 2011 | BenQ T701 TFT 17" LCD Monitor
How to turn printing on and off?
PRINT KEY: To save paper you can only print what is displayed, even in non-print mode. Pressing after the entry of a number will print the entry with the symbol “#” even in non-print mode. Pressing will insert a separator into a number entry such as a code, date, etc. Separators are displayed as a period and dashes but printed as periods. MEMORY + KEY / PRINT ON / OFF KEY: Pressing selects print mode or non-print mode. Cause the calculator to operate in a display / print or display only mode, depending upon the calculator’s present state. “P” on the display: Print mode. “NP” on the display: Non-print mode. MEMORY – KEY / DECIMAL SELECTION KEY: Pressing sets the number of decimal places in the result. “F” on the display: The answer is displayed in the floating decimal system. “3, 2, 1, 0” on the display: Presets the number of decimal places in the answer. “A” on the display (Add mode): The decimal point in addition and subtraction entries is automatically positioned to the 2nd digit from the lowest digit of entry number. Use of the add mode permits addition and subtraction of numbers without entry of the decimal point. Use of , and will automatically override the add mode and decimally correct answers will be printed.
Aug 18, 2010 | Sharp EL-1611P Calculator
PCR T2000A error code 35 (change exceeds preset limit)
Hi. I've never had that before. Someone has probably set an obscure change limit in the machine features. Try this:
Turn key to program mode.
0
CASH
SUBTOTAL
SUBTOTAL
0
CASH
SUBTOTAL
Turn key back to REG and try it
Mark
SUBTOTAL
May 05, 2009 | Casio Parts Cash Register PC Desktop
How to pre set satitions
Your Sony is equiped for 5 AM presets and 15 FM presets.
1. Power your unit "ON".
2. Set the desired band - AM or FM.
3. Hold the "Mode" button down no more than one second. The "preset" indication just be gone.
4. Manually tune in the desired station you want to preset.
5. Hold "Enter" until preset indication re-appears. The number of the preset should be blinking.
6. Using the tuning buttons, change the the number to your desired "preset" number.
7. Push the "Enter" button to set the preset.
Remember, you can't have more than 5 AM presets (a mistake I made).
Phil20124
Jul 16, 2008 | Sony Walkman SRF-HM33 AM/FM Radio
How do you delete the presets in my unit?
I was looking for a solution of my problem but found your problem. I have a manual but it is not aesy to find a way to erase all presets. Read this selection till the end and you know a way!
It is possible to change the MW tuning interval. You can do this by pressing the POWER button while pressing the BAND button during power is on. To reset the interval, repeat this procedure.
NOTE
- When the MW tuning interval is changed, all preset stations are cleared. The preset stations have to be set.
Hans of the Netherlands.
Feb 18, 2008 | Audio Players & Recorders
Gateway GT5220 PC Desktop Logo
321 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
