Question about IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR KIT-Air Brush
Air compressor regulator
Hi, I just bought this kit a few days ago. My air compressor just fell from the table and the black air regulator (with that red ring) just came off together with a rubbery circle, a white ring and thick golden spring. I put everything together (guessing) but now the air comp. is not working as before. that is less air is coming from my airbrush. Any help? Thanks a lot, regards, Jonathan
Hi my iwata powerjet lite shut down.theres power but no performance.it only gets used for prob ten hours a week,somtimes weeks without use.is this common and expansive to repair.thank you.re ****.
Posted on Feb 21, 2011
I have a Hilti air compressorand it will not stop building preasure. How do I adjust it?
The pressure regulator switch needs to be replace. This the little black box that your power cord comes out of. It screws into the compressor. You must remove the wires going to the electric motor. Then unscrew from compressor and replace with new regulator.
May 03, 2014 | Emglo KU Pump Valve Kit
This is a brand new compressor that I have kept in a box for about six years. It was never used. I open the box and took the compressor out of the box. The regulator fell out of the compressor. I have...
Look at the underneath side of the knob. Many of these have a square molded into the knob that fits over the square shaped adjusting stem coming out of the regulator. The replacement regulator (if you end up having to replace it) is part #885807 (reference number 30) and is $42.88 Here is the link to the parts breakdown.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/hitachi/EC119SA
Jul 16, 2011 | Hitachi EC119SA Twin-Stack Air Compressor...
Hi, two days ago I bought a Danby Premiere DPAC13009 portable AC unit. It worked on the first day reducing the temperature from 32C in the room to 26C in a few hours. Although now there is no cold air...
Comperssors have a thermal overload. If there is a starting problem or low on freon the conpressor will shut down until cooled off. Try restarting and listen to compressor.
Sep 03, 2010 | Danby Heating & Cooling
Our air compressor TC 196 fills when turned on and then it starts leaking out of the silver hole on the black box. It was fine a few weeks ago and we have a show in 2 days. Help!
it will be a velve, perhaps the tank oneway inlet velve then when the compressor shuts off its hitting the unloader therfor the air in the tank is escapeing, but you didnt say you loose presure.hope this helps
Jul 27, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Power on are compressor, hear buzz, but pump did not start .
if its just humming and not starting you may have a motor start capacitor on the motor thats bad and can't supply the starting voltage against the compressor
May 09, 2010 | Campbell Hausfeld 28 - Gallon Air...
No air pressure thru quick connect to tools-bag regulator?
I dont know if it is like mine,but if you can let the air out of it and remove the regulator knob,and it`s components,you may can set it to just to be open all the time,in other words,by pass the control knob valve.Shout back at me if I can help.
Nov 06, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Dewalt D55155 air compressor regulator installation
The d55155 unit suffers from regulator problems due to weakness in the design of the manifold. The manifold parts are very light duty metal and will break during installation if not carefull. If you can return the parts to dewalt it may be more efficient to to use a generic pressure regulator from www.grainger.com for about 20 bucks and mount using a couple of 1/4" tees directly off the pressure switch. Remove the hose from the pressure switch that feeds air to the manafold . Install parts so that the quick disconnects, guages and new regulator are accessable from the side. It will not be pretty but problem will be solved for long term. We repair other brands that come with control panels using the same method. Pressure regulators built into a manafold will fail. For demanding customers we have recreated the manafold using 1/4 pipe fittings and refit the gauges and grainger regulator into panel.(lots of work) But leave the safety unloader at the pressure switch. If all you need is a good functioning compressor same time and money and mount to side. Good Luck and email if you have questions or other issues with your dewalt.
Feb 19, 2009 | Black & Decker Dewalt #D55155 2HP 4GAL...
IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR KIT-Air Brush Logo
236 people viewed this question
Top Iwata Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Iwata Air Tool and Compressor Expert? Answer questions, earn points and help others
