Question about Proform CrossTrainer Treadmill
Stops while in motion
The belt on my tredmill stops while I'm using it
    President:
  • Proform Master
  • 832 Answers
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug instops while in motion - 2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
Posted on May 16, 2010
Get on tredmill it stops
Having the same problem, was wondering if you found an answer. I also noticed that my belt, track, whatever is out of alignment. I am wondering if it is some sort of safety thing if the track is off line.
Feb 28, 2014 | HEALTHRIDER R60 SoftStrider Treadmill
Reebok Treadmill error code 5
Exactly same just happened to my brand new Zr9 (error 5). Reebok said they would replace the motor or complete tredmill or my money back. Undecided as to what to do but thought i was buying a reliable bit of kit ??? They do cover it with 2yr warranty and it is really nice use, will research a bit more before deciding.
Feb 20, 2014 | Reebok Exercise & Fitness
Tredmill stop when walking
Try to tension the Walking belt. If the walking belt is not in tension then the belt will stop when you step on it. Watch the video to find how to tension the walking belt. Every treadmill follows the same procedure.
Sep 26, 2012 | Proform XP Weight Loss 620 Treadmill
I have a HSW1175 Hornet Tredmill which goes for 7 seconds then has a E1 error, please explain???
This conditions is abrupt shutdown of the belt as motor detect a sharp increase a drive currente and inmediately stop driving belt.Ohter situation is jammming the belt, may cause this error.Extreme care and analysis for service technician, required.
E.CUADRA
Nov 03, 2011 | Exercise & Fitness
When i get on the treadmill the belt stops all of a sudden
Try to tension the tredmill's belt. For that you need an allen wench. Watch the following video to adjust the running belt. All the treadmills uses the same way to adjust the belt.
Oct 10, 2011 | Reebok Vista Treadmill - RBTL13305
Proform tredmill---stops after a couple of steps--will start back up after getting off---motor control board?
Inspect the walking board and belt first.Feel the tecture at the outer edge of the belt, then feel the center. If it feel fuzzy, the walking belt is worn.
Check the walking board for damage, deep scratches, excessive friction will cause an over current shutdown of the controller.
If the walking belt and board are good, lubricate the walking board and belt and try again.
Does the motor spark allot when running?? This will also cause over current.
Have you tightened the belt (too tight??)
After covering these suggestions, if the same problem is apparent, change the motor controller..
Dec 16, 2010 | Proform 755cs Treadmill Motor Control...
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
After 10minutes the tredmill stops
Either you are forcing it to go faster than the set speed or not keeping up and it is trying to compensate. Eric
Aug 03, 2009 | Exercise & Fitness
Proform CrossTrainer Treadmill Logo
301 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
