I have a frontloading Kenmore washer purchased in 2003. The door will not close, and there is a wire ring that fell off. Can I fix this myself? It looks simple but I don't want to make the problem worse so I'd like some guidance.
  • 5,911 Answers
The wire ring you are referring to is called the front bellow clamp. This is the clamp the holds the bellow (door seal) in place. This may be causing the problem you are experiencing with the washer door not closing properly. The following link explains how to access and reinstall a door bellow and clamps:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
As long as the spring is still intact on the wire hoop and not broken, the clamp can still be used.
After UNPLUGGING the washer, skip down to step 12. This is explains how to reinstall the wire hoop. Just make sure the bellow seal fits snug all the way around the door perimeter. Then, fit the wire hoop into the groove around the seal. It helps if you have a second person hold it in place as you install it.
Overloading the washer is the most common cause of the front bellow clamp coming off. If there are too many articles in the washer, they can become lodged in the door area and pull on the bellow. Always follow your manufacturer's recommendations in the owner's manual for proper loading.
If the door still won't close properly, you may have a broken door latch mechanism. Check the latch pin on the door and the latch on the door facing and make sure they are still mechanically sound and not broken. If the latch needs replace, the following link explains how:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on May 01, 2010
When I was fixing the door switch for my Kenmore front load washer this spring fell out. Where does it go?
I've seen that door lock assemble before and I normally just replace it. But good job on your end to give it a go. That door lock has a coil that when energized it closes on the door strike. When its de-energized, that springs assist to open the lock. I can say exactly where it fits, but look for a spot between the red part on inside. Good Luck
May 25, 2016 | Kenmore Washing Machines
Kenmore HE2 washer stopped in teh middle of the washing, no power and can not open the door. Please help me in opening and fix it?
All frontload HE washers have a rip cord you can use to manually open the door but try to clean out your pump filter first. Your tech sheet is also there behind the service panel. Simply going by the diagnostics and cleaning out the filter could save you a bunch od money. Here is a nice video which shows how. H.E. PUMP FILTER CLEANUP
Dec 13, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore frontloader HE 4T makes a clicking sound when i try to start it and the screen displays a F dl. I cannot find my manual to solve the problem. Any suggestions?
The FdL error code indicates a problem with the door lock assembly on the washer. The control board detects that the washer door is not locking properly. Replacing the door lock assembly will normally fix this problem. It can also be caused by a wire harness connection failure or sometimes by a failed control board. You can order a new door lock assembly from the Sears Parts Direct website www.searspartsdirect.com . Use the full model number of your Kenmore HE4t washer to order this part. Most HE4t models use part number 8181700 for the replacement door lock. ------- To get how to replace door lock instructions ,please click on link below:-- http://media.fotki.com/1_p,wftwwwsbfbfftdkxgtqsskgwtqkq,vi/gqkgsfgsfxgwrsfbktg/1/1303472/5961857/image27677img-or.gif --------- You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Kenmore Washing Machines
Frontload washing machine makes noise during spin cycle
call sears 1 800 4myhome they can walk you thru some troubleshooting. First thing pull back the rubber ring between door and barrel to see if anything like pens etc feel into the gap underneath. If not call for troubleshooting. Get a plan with sears then wait 30 days and call in the problem. Fix will cost less.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Door opens on the wrong side
Usually not. If you can you will need a door kit from sears. But in most cases the manufacture does not want to mess with the doors seal, so they dont offer a change.
Jan 24, 2009 | Kenmore 44072 Front Load Washer
Front load Kenmore HE3t washer wont start
If I remember correctly you have to move the door boot seal out of the way by removing the wire ring underneath to get inside to the door switch there are two screws holding in the latch on the outside
Apr 18, 2017 | Kenmore Elite 45986 Front Load Washer
Please help , tell me why door is locked, on h 2 kenmore washer,
THANK YOU,
still nothing,
red doorlock light on, wont do anything,
I have to unplug so it will shut off,
when I plug in and hit start, red light stays on again,
Mar 28, 2008 | Kenmore 4292x Front Load Washer
Front load washer won't start unless door open and closed over and over
the door latch needs a spray of crc into it as it may be a little dry inside there
that should fix problem
if not replace door switch
Mar 15, 2008 | Washing Machines
Kenmore washer smells/mildew on rubber
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile. please rate my help
Oct 04, 2007 | Kenmore 44102 Front Load Washer
Maytag frontload washer door is leaking
Yes you can do it. the door boot has come off the tub opening. first you will have to push on the door boot (gray rubber)on. There is a grove that slides into the metal opening in the washer. make sure the the door boot (gray rubber)lays flat against the outer opening. then with the spring at the bottom . start at the top put the wire in the rubber grove. until you get the the spring then pull down on the spring and tuck it into the grove.. I hope this helped [lease let me know if you get it... krazytech
Sep 13, 2007 | Washing Machines
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
