Question about Kenmore 62802 Electric Dryer
I start my dryer and it seems to be operating ok but shuts off after a few minutes. Is it a bad timer?
  • johnabuck May 01, 2010
    Hi - model number from inside door is: 67902790 - 67902; Type is: 138-00; Serial # MH1549758. Thanks for any advice! - John
    Seems to have done the trick! thanks very much. - John
    President:
  • 949 Answers
I would not think it would be the timer.
If I understand your problem it runs for a while okay then stops. After a while are you able to start it up again? If so it is more than likely the motor is overheating and shutting off.
This could be do to a heavy lint build up on the motor that is causing it to overheat. If cleaning it does not work then the motor needs replaced. If you can send me the entire model number off the tag just inside the door I can help you take it apart to clean the motor if you like.
Posted on May 01, 2010
  • Philip May 01, 2010
    Hi John,
    Thank you for the numbers. I have the wiring diagram up here. There are only a few components that could be causing the problem you are describing.
    I am still leaning toward the motor overheating. Are you okay with taking the machine apart and checking some things? If so I will put together details on how to take it apart.
    Here are steps to clean the motor
    - Unplug the dryer cord.
    Use the image below these instructions to help. The numbers in parenthesis on my instructions refer to the numbers on the image below.
    - The lower panel (61) is held on by clips (46). insert a putty knife or screwdriver and push on the clips while pulling toward you on the panel (61). When released lift the panel off and set aside.
    - The motor will be mounted on the base of the dryer to the left side. Use a brush and vacuum to clean the area and motor from dust and lint.
    - If the cleaning process does not repair the problem the motor (image and part number below) will need replaced. The price for the motor is about $140.00.
    - If you need more instruction let me know
Dryer will heat and spin. After a few minutes it stops. Try to push to start button and nothing happens. I wait about 20 minutes and it will start again. What is the problem ?
Mine was doing the same. I got a bit of a rattle noise in the timer when I'd try to restart it though. First I unplugged the dryer, I took the control head off, then I took the timer out, and opened it up. Found that 2 of the copper contacts were covered in black soot and had a little corrosion on them. I took some fine grit sandpaper and sanded the contact only till they were smooth and clean. I only did this a short while ago but seems to be working so far. It hasn't prematurely shut off and the timer is turning again.
Aug 26, 2010 | Kenmore 62602 Electric Dryer
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
Model MDE5500AYW. Seems like dryer occasionally overheats when in sensor dry mode. Lint screen and vent are clean and plenty of air flow. One time the sensor works fine (minute timer drops and unit shuts...
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
Feb 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Hi,Dryer wont restart
def. sounds like a bad or failing motor situation... motors cost anywhere from 125 to 200 dolloars... not too hard to replace though....
Sep 24, 2009 | Whirlpool LER7646E Dryer
Whirlpool LER4634EQO Runs for about 2 minuts and shuts off.
It is possible your Cycling Themostat is not working properly. It determines at what temperature to turn heat on and off to maintain a consistent dryer temp. The High Limit Thermostat would turn off the heat but your dryer would still run. That leaves the Thermal Cut Off which is turning off your dryer. It might be faulty and turning off at too low a temp, or it might be doing it's job. In that case something else is wrong. If you can check the exhaust air temperature at the dryer, it should be under 175 degrees. If you are absolutely sure the vent is clear, then replace the Dryer Cycling Thermostat.
Aug 25, 2009 | Dryers
Dryer gets to hot
Start with the vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If the vent is ok, turn the timer to any on position without starting it. Wait 10-20 seconds and then check if there's heat inside the dryer.
If yes, the element has a short and therefore always stays on. Replace it.
If no, run the dryer for a few minutes and listen for the clicking of the relay which cycles the element.
If there is no clicking sound, check the hi limit thermostat & thermal cutoff for continuity and replace if necessary.
If those seem ok, it could be the motor (centrifugal switch inside) or the timer (shorted contact).
If not
Feb 21, 2009 | Whirlpool LER4634J Electric Dryer
Dryer keeps shutting off after few minutes.
It sounds like to me that the timer may be bad. Does your breaker trip when this happens? If it does, then it is probably not the timer. The motor turning the drum might be going bad. It could be building up resistance then cutting it off on overload(current). Try to bypass the thermal overload switch which is located under the top. This may very well be your problem. Let me know how this does.
Jan 28, 2009 | Frigidaire GLEQ642A Electric Dryer
Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
Sep 23, 2008 | Dryers
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 62802 Electric Dryer Logo
73 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
