Question about Estate ETW4100SQ Top Load Washer
Washing machine leaking water from underneath
I walked into my laundry room to a flood of soapy water..after cleaning it up, i put in a small load and turned the machine on. During the first 5 mins, I notice water starting to puddle out from behind my machine. It is obviously coming from underneath. Before I move my dryer out so that I can move my washing machine over and look underneath, any suggestions of what I am looking for? Could it be just a loose hose or something?
Thank you,
Lori
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
It is possible it is just a loose hose or it could mean your trmp or the tub itself is leaking. I would try going to the back of the machine and take off the bottom panel.and take off the back panel. After removal start it and observe where the leak is happening.
Posted on Jun 14, 2017
ngafm
  • 166 Answers
SOURCE: washing machine leaking at the connection to water pipe.
Hi vks1,
Your water is coming out into the washer even when you water supply is switched off at the pipe?
Disconnect the washer hose from the water pipe and see if the water still comes out of the water pipe even when the water valve is shut off!
If the answer is YES!
This is a plumbing malfunction.
The valve on your water pipe is not closing completely!
There is a washer in the water valve attached to the end of the valve stem that more than likely needs replacement.
And not a washer malfunction.
If I understand your explanation correctly this is the cause.
If this is not the problem then the washer has a water inlet that is stuck open.
But this dose not make sense if the external water valve is shut off there should not be water reaching the washer inlet faulty or not!
I believe I figured out the problem for you and you will be fine when the valve is fixed or the valve stem replaced!
Bless You,
ngafm
Let me know that you have succeeded!
Happy to of helped you.
Please give me a good rating before you sign off our site!
Thank You
Posted on Sep 10, 2008
  • 2920 Answers
SOURCE: Leak from pipe/wahing machine drain hose
try running the snake from the top to the bottom. they ell pressure hose ends that you inser into the pipe on the end of a hose and when you turn the water on it weslls and applies pressure to push out whatever is in there. they cost about 8.00 and you can buy them at lowes or home depot. just tell them what you need and that it screws onto the end of a hose for unclogging backed up drains. im not sure whats its called but they will know
Posted on Feb 01, 2009
  • 225 Answers
SOURCE: Taps that connect to washer water hoses are leaking
first of all make sure water water is shut off to washer,you can take the handels off take the nut off that holds the valve in place there you find either a rubber groumet or o ring replace that put back together should fix your problem.
Posted on Jun 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have just bought a
Ok I suspect you have a broken lid switch. themobilian_122.jpgSwing up the controls and first check the water level switch for: pinch tubing. tubing not connected, blow out the sediment in the tubing from when you moved the machine. Make sure that tubing is tight on the switchthemobilian_123.jpgNext check the lid switch connectionthemobilian_124.jpgLook for it to be plugged into the lid switch on the case of the washer. In my hand there is 3 wires to that switch 2 hot wires and one green ground wire. Jump them 2 hot wires and see if it will spin or pump out. How to swap out that lid switch:
I have more vdeos of common repairs on this nice machine HERE
Posted on Nov 12, 2010
SOURCE: washer leak in an estate washer
i have Had 3 estate washers leak on all four corners....there junk went with ge instead......estate washers are horrible
Posted on Feb 07, 2012
I put a load of clothes on to wash and left the laundry room and everything was fine. When I returned the whole laundry room floor was flooded! I can not see where any of the incoming water lines or the...
Did you have a small part of clothing sticking out the door? Water can leak past the door seal on this case. Other than that, run the machine empty u ntill you find the leak location.
Jan 19, 2018 | Kenmore 24832 Top Load Washer
Washer fills up and does not stop filling just flooded my laundry room
The "water valve inlet" need to be replaced in the machine. Here is a link to the part. Here is a link to a video to walk you thru the repair.
Dec 05, 2010 | GE WWSE5200B Top Load Washer
My Kenmore 800 series washer leaks from under the front left during the spin cycle. I looked behind it and checked the connections but all seems fine in that area. What could be causing this?
Same problem! Flooded the laundry room and about 1/4 of the basement. Happens randomly, not every load. Checked all hoses, they are snug and don't appear to be leaking at all. During the wash cycle it you can hear it spraying water inside the washer and the floor starts flooding. I bought the washer Sept. 19, 2009 and have had this problem for about 5 weeks now. Sears refuses to do anything about it, because it's no longer under warranty.
Aug 07, 2010 | Kenmore Washing Machines
Won't shut off machine turns off after a few seconds
You may have a burnt motor. This is usually caused by a clog in the pump. Sometimes small items such as socks find its way to the pump. It could also be the timer itself. If there is a burning smell when that happend it is probably the motor.
Jun 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water not shutting off to begin wash cycle flooded room
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Jun 01, 2009 | Washing Machines
Door pops open during wash cycle
this is joyce
What I would do in this situation is fix the door lock first before I would do another load of clothes. you can go to Kenmore.com put in your model # and download your manual to your machine if you want to fix yourself
or you can call service tech out. I will help you find one in your area if you need.
thanks,
joyce
Feb 04, 2009 | Kenmore 44072 Front Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer fills till flooded
change the fill valve located where the hoses hook up
Dec 29, 2007 | Washing Machines
Estate ETW4100SQ Top Load Washer Logo
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
