Question about Maytag Neptune MDG5500AW Gas Dryer
One of the 3 wings fell off inside dryer drum.
How do I replace the screws that fell out
  • Maytag Master
  • 2,286 Answers
Unplug the dryer,open the door,remove the two phillips screws that hold the door on,the screws are in the middle of the hidges,look at the other side and remove the two screws that are there,pull off the front panel grabbing it at the top where the top screws were and pull forward the bottom of panel is on clips,just slide the panel up off the clips,now spin the drum until the baffle that you need to repair is in the lower right hand corner and you can get to it there.if the holes are to big for the screws add a washer to stop the screws from falling through the holes,sometimes the screws get ripped through the holes making the holes to big for the screw heads and a washer needs to be added,let me know how you make out
Posted on May 01, 2010
Testimonial: "thank you so much. This worked like charm."
  • k corkett Sep 18, 2013
    Worked, thanks. Had to use crazy glue, as the plastic part that the screw goes into, ripped off the inside of the wing. So far it has held up. Might eventually have to replace the wing, or crazy glue it again in the future. Thanks.
  • Sal DeAngelo Sep 18, 2013
    glad i could help and good job repairing it,you want to watch out with using glue or something like that,the dryer gets hot and if the glue has an oder to it when it gets hot it could get into your clothes but i think you'll be fine with the crazy glue.
Kenmore stacked laundry unit. when it was plugged in sparks flew and small parts of the heating element fell and the power cord is ow black. can we replace cord and be ok
Heating element must be replacedas well as the cord. Make sure the drum screws were not screwed into anything electrical.
May 18, 2013 | Kenmore Dryers
Inside the drum, there are three "panels" attached to to the wall of the drum. I guess they are used to tumble the clothes so the heat is evenly exchanged? One of the panels broke off. ...
It wont hurt anything to use it like that. The screws probably fell outside the drum when they came loose. You can look at the other two to see how they are fastened if you want to put it back on.
Apr 01, 2011 | Dryers
The drum wings broke off, how do I replace them?
remove the front cover,this will then let you revove the screws for the top cover then you can access the paddles/wings
Oct 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Interior drum one of the three turner shelves fell off into the drum during the cycle - help
Unplug the dryer
Unplug the dryer
UNPLUG THE DRYER
remove the top and remove the front panel look for the screw(s) that fell out at the inside under the drum use a flashlight and a magnetic pick up tool screw the baffle back in replace front and top.
Sep 03, 2009 | Maytag Dryers
Drum makes noise after I unscrewed the screws inside the machine.
You will have to remove the drum from the front and replace the drum support cup kit.
May 23, 2009 | Frigidaire FDE647RF Dryer
I have a Kenmore 70 Series gas dryer, model 76712691. The dryer has 3 plastic ''tumblers'' inside the dryer, to help the clothes tumble. Two of the tumblers have fallen off inside, leaving big holes inside...
Pull the dryer away from the wall, there is no bottom on the dryer, so the screws should be on the floor.
You can then pop the lid up from the front and fold it back. When you do, you will see the drum. Roll the drum around until you see the holes and reattach the tumblers.
You can also access the drum from below. Tip the dryer on its back and you can see the drum from the bottom.
Good luck.
Regards,
May 15, 2009 | Kenmore Dryers
Inside paddle fell off
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top.Rotate the drum around and reach inside the drum. Re-attach that baffle.
Apr 09, 2009 | Whirlpool LER5636P Electric Dryer
Fins fell off tumbler on Whirlpool Ultimate II dryer
Remove 2 screws under the lint filter cover, then using a spatula or similar, prize apart the top cover from the cabinet, lift top cover and support it.Turn drum by hand until the drum baffles are at the top, and refasten the baffles one at a time.
Then lower cover down and press until it is closed, replace 2 screwa under lint cover.
Job done.
Plz rate this soution.Thanks.
Jan 01, 2009 | Whirlpool Dryers
Need to know how to reattach the dryer drum
ouch budddie...happy new year ...looking in the dryer are you taking about those there center mass,,,if that attactes the back bearing surport to the drum...,,if that the two parts which i think your talking about ..you have to take the drum all the way out,,because those three screws are shape like a piece of pizza....it will never line up with drum in...
Jan 01, 2009 | Frigidaire Dryers
Plastic wing inside the drayer drum fell
Replace the fin if you have found that it is broken.
May 27, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
274 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
