Question about Samsung WS-32M066V 32.28 inch TV
I have a tv digisender (Nikkai) which works fine with an analogue tv on a scart lead, but not via a scart lead with a Kenmark dtv. (Error message is no signal received) Help!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 182 Answers
You have to select scart on the kenmark tv from the source menu as your digi receiver probably does not have an av switching voltage
Posted on Jun 07, 2010
Phillips DVD recorder connection issue?
SCART is designed to carry analogue standard definition content. So if the input signal is high def. it will distort.
Jun 09, 2014 | Philips Televison & Video
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Sep 26, 2017 | Televison & Video
Following the beginning of digital switchover, pressing the menu button only comes up with 'picture quality' and is unable to access 'installation'.
If your TV is not in Digital it won't give you the tuning option.
Select DTV from the on screen menu, (like scart 1 scart 2 etc). When you have found DTV select it and then press menu for tuning.
Hope that helps.
Mar 30, 2011 | Televison & Video
VCR playback to TV
Has the TV got more than one scart socket? If so try a different one, as some are not designed for VCR playback. Also the scart lead must be fully wired, check that it's not damaged (look at the pins carefully). Scart leads are good at causing all sorts of trouble, so make certain you have a good quality new one connected.
Feb 19, 2010 | Televison & Video
I cant play a dvd on my flat screen 22 inch kenmark
you do not say if the tv has built in dvd if so a common problem is the disc in the wrong way round if you are using an external dvd and it is connected via a scart lead predd scart in the source menu.
Sep 01, 2009 | Televison & Video
Connecting sky box to to non scart reysis tv,via scart plug cable
This lead is usually coloured yellow and looks like the red and white leads you use to connect the tv speaker OUT sockets to an amplifier or external speakers. The input on the tv should be coded yellow also.
Jul 18, 2009 | Relisys RLT-1500 15" LCD Monitor
Samsung LCD TV LE26R51BDX - No analogue TV or Freeview
Are you sure the TV has a built in tuner? Does your country have digital over air broadcasting like my country or not?
Mar 03, 2017 | Televison & Video
Lost the manual to Kenmark tv
What model of the tv do you have .under normal conditions it would be connected to the sky box via a scart lead. If this is the case bring up the menu on the tv and select scart input . this should then work
Apr 16, 2009 | GE RM24911 Remote Control
Reception upgrade or what ?
Older sets are fitted with analogue tuners which can't handle digital signals. The only way round the problem is if the TV can be used as a monitor via a scart input. The external freesat or digital set top box contain digital tuners which can then display the required digital information on the TV. These external units have scart output sockets at the back, specifically for this purpose. So it's a scart lead from your external digital device to the scart input socket at the back of the TV. The remote control for your external box is then used to select the required programmes
Oct 24, 2008 | Panasonic Televison & Video
RCA - 4228ASPDP - 42 inch Plasma - Audio Problems
Usually you would connect the SKY box to the DVD recorder and the DVD recorder to your TV, check you installation guides for setup instructions, which should show you a preferred layout diagram,
Sep 27, 2007 | Televison & Video
Samsung WS-32M066V 32.28 inch TV Logo
146 people viewed this question
Jerry Greenberg
Jerry Greenberg
