Question about Zebra 170XiIIIPlus Thermal Label Printer
I am printing bar codes. In the bar code it is laying down more ink then it should leaving big lines that can be sracthed off. I am using a Zebra 170 XILLL PLUS.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
In the software provided adjust temperature setting of print head before printing the job. Please also check for bad ribbon. Please don't hesitate to ask if any further assistance is needed. Good Luck
Posted on May 01, 2010
Zebra 110Xi III Plus Printing Bar Codes too dark
if it is the least setting for print head then you may need to dry ribbon by putting in sunshine for few hours
Apr 23, 2013 | Zebra 110Xi III Plus Thermal Printer
Have a Zebra 105SE that prints the FEED test just fine, but will not print the PAUSE test nor will it print a bar code label from the computer. The FEED test prints vertical bar codes while the PAUSE test...
Check to see if the pause light is on also. Make sure you are using the correct printer driver. (105se)
Try in ZPL and then try in ZPLII.
Check Delimiter character 2CH
Check Format prefix 5EH
Check Control prefix 7EH
Aug 24, 2010 | Zebra 105Se Thermal Printer
My printer has problems printing dark colours. When printing pictures or text, it leaves horizontal lines on black only. I have a continuis ink system which has lots of black. Any ideas?
Try changing the print paper type to something other than plain paper. Use the matte paper setting, or the photo glossy. The printer will lay down more ink at these specialty settings.
Jan 24, 2010 | Epson Artisan 800 All-In-One InkJet...
I have a Zebra 110 XiIII p it does print different size bar codes
Keeping up with the Drivers is a very good idea, it will fix little problems that come along from time to time. Try resetting the printer defaults by entering the menu system and exiting, at piont of exit don't save permanently but cycle around to load defaults and exit. Go back in and set the printer up again, this time exit saving permanently.
Jan 21, 2010 | Zebra 110XiIIIPlus Label Printer
All of the sudden my bar codes are not fully printing. Missing some lines on the bottom. Also the numbers are not printing rel clear. Have ran this label before and no problem. Now it is all bar codes.
Try cleaning the printhead, then print the zebra test print. (see user manual) or just print a solid black box 4" wide by 1" long. If you have white vertical lines through it you may need a new printhead.
If print test is good try increasing the heat/darkness setting
Nov 09, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Zebra TLP2824 label alignment problem with MYOB Retail Manager
Ensure that the label size in your MYOB and also the printer driver are set to the same as the physical size of your label. Also do a callibration on the printer.
Oct 14, 2009 | Zebra TLP 2824 Printer
ZEBRA printing issues via AS400
*SAME
*WSCST
ZEBRA
*LIBL
*NONE
'10.27.9.21
Jun 26, 2009 | Zebra 105Se Thermal Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
Printer won't print
check for paper jam and the ink.
green flashing lights means it try to print but something is holding it back.
Oct 14, 2008 | Zebra LP 2844 Thermal Printer
Bar codes appear solid back
I have problem with the same printer, the bar code is not printed, someone can help me?
Apr 09, 2008 | Zebra 105Se Thermal Printer
Zebra 170XiIIIPlus Thermal Label Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
