Question about Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive
Morning how do I retrive data from a failed hard drive
    President:
  • 2,049 Answers
Retrieving data from a failed harddrive can be very difficult and often expensive. If the failure is a result of an overheating motor, one way that I've been able to do it is by putting the harddrive in a sealed plastic bag and putting it in the freezer for 1 hour. Immediately place it in your computer and fire it up. If it works, recover your datat quickly has it will fail again as soon as the motor overheats.
That being said, if this data is absolutely critical, do NOTHING to try and recover it and send it in for professional data retrieval. I say this as any recovery efforts on your own may possibly damage your harddrive further.
I have used Seagate's data recovery service (all makes and models accepted), but be ready to spend quite a bit ($800+). That isn't much if the data is critical.
https://services.seagate.com/
Posted on May 01, 2010
Western Digital Crackling noise
This hard drive maybe still under warranty, I recommend you get a replacement and back up your data before the hard drive fails completely.
Jul 11, 2012 | Western Digital My Book Essential 2 TB USB...
My notebook fell off table, did not break externaly but now fails to detect hard drive . what can i do to fix
Unfortunitly, you hard drive's needle may have been knocked out of wack and will not access the data anymore. 2 solutions here:
1. New hard drive and reinstall everything. (Easy)
2. Let a data recovery provider retrive the information from the damage disk and put it on a new one. (Expensive and time consuming.)
Good Luck
C2Solutions
Feb 15, 2011 | Computers & Internet
Good morning. I have installed in my Company a Iomega nas model 450R. This morning after a reboot,it seems it can't find the boot disk and the nas asks for a operating system restore or go back to factory...
It seems that the main hard drive in this server either went bad, had a windows corruption or that one of the internal connections inside this server went bad.
You would need to check on all three of these areas to make sure 1) the main hard drive is functional (which is my first suspision so check the hard drive for errors and if it fails you would need to do a data transfer to a new hard drive). 2) use your windows software to repair the dammaged registry that may have been corrupted somehow (only do this if the main server's hard drive passes its hardware tests).
You would need to run the original os but I would need to know which one you are using to guide you more to solving the regisrty issue.
3) Hopefully tis server has a warrenty and it may need replacing if all else is working.
Try #1 which is the highest supected for failed hard drive issue (remember if discovered that main hd is bad you may need to perform a data transfer immediatly and replace with a new hard drive.
any other questions please write back with status :)
Mar 19, 2010 | IOGear Computers & Internet
My WD My Book is not working. It looks like the
if you locate the same hard you can retrive data by changing the controller of the hard drive
Jan 02, 2010 | Western Digital My Book Essential Edition...
Seagate ST3500630AS SATA 500 GB hard Drive
You will have to send it to a data recovery company in order to retrive the data sounds like the circuit board failed therefore the drive is not receiving power.Usually if this board is good you would hear the drive spin up.
Good luck
Oct 04, 2009 | Seagate Computers & Internet
HARD DRIVE STALLS TRYING TO LODE WINDOWS XT PRO
Can you go in safe mode?You might want to retrive your data and replace the drive as it might be failing.
Oct 04, 2009 | Maxtor Hard Drive
Read disc failure
Most local computer shops will recover data from a failed drive for a certain amount. Google "Data Recovery" with your state following that phrase
Mar 12, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Error Message re: KIngston 2G Pendrive
since the device uses usb power there is no way that you might be able to retrive data if the computer wants to format it.
Dec 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Flash drive problem
may e data is corrupt. use some data recovery software for data retrival
May 15, 2008 | Kingston Technologies 512MB DataTraveler I...
Tryi8ng to install portable 120GB hard drive (seagate)
If your USB ports do not supply enough power (older computers) then the drive may fail to show up in My Computer.
The Seagate should have a special Y cable. There are two USB connectors on one end that must both plug into your computer - one for data and power - the other for power only. The other end of the cable has the mini USB which plugs into the Seagate.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=External_Drive_Troubleshooter_-_Windows_Error_Messages_-_Common_External_Drive_Errors&vgnextoid=14d24a3cdde5c010VgnVCM100000dd04090aRCRD#clicks
Mar 22, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive Logo
251 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
