Question about Brother Office Equipment & Supplies
Change unable 51 troubleshooting & routine maintenance replaced new ink and still not working
  • jeannecolomb May 01, 2010
    there is NO set button on this machine!!!
    do you have a list of places that service this printer??
    Sergeant:
    Novelist:
  • 172 Answers
Hi jeannecolomb. Error 51 I believe it has nothing to do with the ink. I Think is more an internal issue. I found this for you. This is applicable for all models of Brother Printers. Hopefully this will help you. In case it doesnt you will need to take it in for service.
  1. Disconnect the power cord from your Brother Printer.
  2. Press Set button, while holding the Set button re-connect the power to your printer
  3. The Error code will be display “Machine Error 46′
  4. If the Error code appear, press the “arrow up button” ( ^ ) there will be numbers that are going to be display.
  5. Choose 8 then press Set Button
  6. Press Arrow Up button again then choose Zero (0) and press Set Button Again, now you will enter Service Mode.
  7. Press “Mono Key/Button” 25 times or until “Purge Counter Appear”
  8. Now press arrow up (^) again then choose “2′ press Set Button
  9. Press Arrow Up (^) again then choose “7′ press Set Button
  10. Press Arrow Up (^) again then choose “8′ press Set Button
  11. Press Arrow Up (^) again then choose “3′ press Set Button
  12. The purge counter will be reset to Zero.
  13. Now Press Stop/Exit Button
  14. You will return to Machine Error 46
  15. Press Arrow Up (^) then choose 9 press Set Button
  16. Press Arrow Up (^) again then once more choose 9 press Set Button
  17. Your Printer will reset then wait until it power up again.
Please do not forget to rate and provide positive feedback for our support today. Thank you :D
Posted on May 01, 2010
  • Leonardo Garcia
    Leonardo Garcia May 01, 2010
    Where are you located?
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
Brother 420
error 51 = The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Fix is
Switching arm assembly not engaged correctly If the switching arm does not move smoothly, clean it.
Ink cartridge/purge switch harness not connected correctly
Correct the connection.
Purge cam switch broken Replace the purge cam switch.
Gear(s) on the maintenance unit broken Replace the maintenance unit.
Paper feed motor broken Replace the paper feed motor.
Main PCB defective. Replace the main PCB.
Cleaning of these print heads rarely if ever is successfull, they are electronic devices unlike other brands of printers
Dec 04, 2007 | Brother MFC 420CN All-In-One InkJet...
Unable to clean, see troubleshooting & routine maintenance chapter in user,s guide
the waste pads need to get replaced. They are saturated with ink. Estimated cost is approx. $70 for labor and $20 for parts.
The whole unit needs to be disassembled.
thakns adi
Jan 26, 2011 | Brother MFC 210C All-In-One InkJet Printer
Clean unable 46
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Apr 09, 2010 | Brother DCP 165C Compact Color Inkjet...
Unable to clean See troubleshooting and routine
the porous pad in your printer need to be replaced and the ink counter need to be reset... you will need to go into the service mode to reset the waste ink counter
Feb 18, 2010 | Brother MFC-5440CN All-In-One InkJet...
Message says "unable to clean" routine maintenance see troubleshooting guide brother MCF 210C
verify all inks yet maybe one or more is empty and run with new inks and original, clean inks yet in you control panel bottom
Sep 28, 2009 | Brother MFC 210C All-In-One InkJet Printer
Troubleshooting routine maintenance
SAME PROBLEM BUT I DONT TEACH. WE HAVE JUST REPLACED THE YELLOW AND THE BLACK INK RECENTLY IN THE PAST WHEN THE PROBLEM WAS UNRESOLVED WE WOULD JUST UNPLUG IT AND WAIT.
Oct 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
unable to clean troubleshooting maintenance user guide
Jun 13, 2008 | Brother DCP 130C All-In-One InkJet Printer
Cleaning
unable to clean see troubleshooting and routine maintenance. unable to use it from then
unable to clean
Feb 19, 2008 | Brother MFC 420CN All-In-One InkJet...
29 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
