Question about Technics SL-MC400 110-Disc CD Changer
When i turn on my technics cd player model number sl-mc409 it comes accross the screen f-26 and won't do anything. what does f-26 mean
    New Friend:
Como soluciono el problema f-26
Posted on Jan 19, 2011
    New Friend:
I've just bought a used changer, that shows the same error. The instuction says " unplug the changer from its outlet, replug it in an turn the changer ON again"
That doesn't help in my case.
Have you found a solution?
Posted on Aug 12, 2010
4 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
SOURCE: Technics SL-MC6 CD player
a) the current CD in use is in slot 23
b) behind slot 23 is a CD left inside
Posted on Jul 31, 2008
  • 99 Answers
SOURCE: technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Posted on Dec 20, 2009
Where can I get a free manual
go on panasonic website or google the manual you want.i use manuals lib
Jul 02, 2014 | Technics Audio Players & Recorders
Technics sl mc409
Loading mechanism is out of aligment. Would need to be taking apart and realigned - something best performed by a pro.
Dec 31, 2013 | Audio Players & Recorders
Please help my 61 Disc CD Juke box just stopped playing and loading CD's all that it does is continuously displays the text message accross the screen stating Quick Change System Mega Changer over
Had this problem with a similar model, the drive belt had stretched and couldnt move the carrige. I replaced the belt with an O ring from True Value Hardware for .59 cents. It works like new now. The size is
1 1/16 outside dia.
15/16 inside dia.
1/16 wall
Captain Ken
Jan 13, 2013 | Technics SL-MC4 61-Disc CD Changer
The door won't stay open when putting in a cd on my Technics SL-PG350
JUust get a different CD- Player ,It will cost you less then to have it repaired, WHere i live i can get a good used one for $10 to $30 at the most, End they are not hot,
Nov 25, 2012 | Technics SL-PG350 CD Player
Hi i have a techniqka hi fi MC-208 when i put a cd in it plays for a bit then 0P shows on the wee window so i cnt play cd... How can i resolve this... Thanks Kerry
try to turn it off an on while holding the play button. try 2 go online an look for the meaning of your (op). type in .technics sl-mc-208 cd player 0P problem
Mar 15, 2011 | Technics SL-MC50 CD Player
I buy a used technics sl-pg480a cd player and after i inserted a cd, there is "no disc" on display...i try with different cd's (mp3, avi,...) and it's always the same...i have opened a box and...
If it doesn't turn the disc it can't read the data and 'know' from that there is a compatible disc inserted.
You may have gotten hosed by the seller. Until you get it to play with a commercial music CD I wouldn't try anything non-standard or home-grown. It doesn't play anything but CD-A music so MP3 and AVI discs would not be recognized anyway.
Before you dive in and possibly wreck it, read this...
http://www.repairfaq.org/sam/cdfaq.htm
The manual:
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-CD-Players/model.SL-PG480A
Feb 20, 2011 | Technics SL-PG480A CD Player
Error code F-26
The servo LSI has malfunctioned.. but I don't know what that means, and where I can get it fixed.... do you??
May 30, 2010 | Technics SL-MC700 110-Disc CD Changer
CD's come out distorted on the TECHNICS SL PG 580A
TRY NEW RCA JACKS AND TRY BLOWING IT OUT,,GET YOU A LASER LENS CLEANER
Feb 26, 2009 | Technics SL-PG480A CD Player
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
704 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
