Question about Omega Simoniz 1300 Psi Pressure Washer
We are trying to put together a Simoniz 1300 PSI Pressure washer and we cannot get the hose installed do you have instructions for this unit
Use a little vegetable oil (or water, or spit) around the "o" ring, wiggle the center-part (the hose) in first. Meaning don't try to use the screw-on ring to force the hose in, grasp the hose itself and wiggle downward. Once you feel it seat, then screw the ring down.
Posted on Sep 29, 2011
  • 623 Answers
Nozzle emits water at city pressure whether pump is on or off
on the lower right side you will see a cap screw thake it out and there will be a spring and a sliding valve. Take the valve out clean it andlube it with silicone grease put her back together and go for it GOOD LUCK...
May 18, 2014 | McCulloch MH1300 1300 PSI 15 GPM Electric...
Hy; I have a karcher 580 I had to replace gun complete so I bough a simoniz xe01-001 at simoniz.osirus.ca/ for your info 69$ complete ***.I install NOW I get pulse up & down ONLY when trigger is press...
Most likely problem is that the tip is too small causing Unloader to bypass or restriction/debris in tip. Install clean tip of proper size or 1/2 size larger (example from 2.5 gpm to 3 gpm ) to prevent slow pulse. If tip is clean and /or larger tip does not help, Unloader may be failing if the unit has a good deal of hours or if machine is left running for long periods of time without spraying. Try lubing the internal parts by removing both hoses and installing a short piece of water hose to intake and slowly inject light oil into pump by pulling on the rope slowly to **** in the oil until it comes out the pressure side. This will displace all the water from inside the pump. Leave overnite. There is a kit sold on ebay to help facilitate the infusion of oil but no need to get fancy. Unloader repair kit is usually available if all else fails and is easy to install. Good holidays
Dec 12, 2010 | Karcher 2500 PSI Pressure Washer
My karcher has a hole in hose close to unit can i cut it and put back in
if the hole is in the gun hose then no.
it will need to be replaced. try bunnings warehouse.
you may need to purchase the gun & hose together.
Dec 11, 2010 | Karcher PSI Electric Pressure Washer
Solutions won't feed from bottles on machine? I use the switch on this machine to use a deck cleaning solution and the bottles won't feed the solution into the water.
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
Jun 25, 2010 | Campbell Hausfeld 1800 PSI Electric...
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
Can't seem to separate the lance from the gun. Got the unit from an estate and it hasn't been used in 2 years.
hey there...
If the lance and hose have been sitting for an extended period of time, they may have rusted inside, and are likely to cause issues when they are put back in service. Usually best to replace the expendables like hoses and guns if they have gunked up. 1300 psi is not much, but with a restricted lance nipple, you're getting 700psi...
Jan 31, 2010 | Campbell Hausfeld 1,350 Psi Electric...
No pressure on simoniz gas pressure washer
May 03, 2009 | Garden
Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Aug 19, 2008 | Electrical Supplies
Omega Simoniz 1300 Psi Pressure Washer Logo
817 people viewed this question
Top Omega Garden Experts
cwradio73
Rodney Carroll
Level 1 Expert
randy yarpos
randy yarpos
Are you an Omega Garden Expert? Answer questions, earn points and help others
