Question about Dirt Devil CE6000 Featherlite Wet/Dry Vacuum
The vaccum won't pick anything up - Dirt Devil CE6000 Featherlite Wet/Dry Vacuum
  • 8,404 Answers
You have a clog in the dirt path ... Inspect and clean it from end to end. You will probably need a broom handle and a screwdriver.
Posted on May 01, 2010
Testimonial: "Thanks. My smart wife looked at what you suggested and we got it fixed. A string had gotten in and clogged it. Thanks for your help!"
  • A Miller May 01, 2010
    thanks for the 4 thumbs ....
    amazing ... Im glad you got your machine working
    thanks for using FixYa.com
Why won't my shark navigator cordless vacuum pick anything up?
Sometimes everything seems to be fine. The brushes turn, but if the brushes aren't cleaned of hair, rug tangles and so on, the brushes on the vaccum get filled and it won't puck up anything. ON THE OTHER HAND if the brushes are clean, did you check all your hoses from thr base of of vaccum where things get sucked up to the bin?
Jan 27, 2016 | Shark Vacuums
It won't pick up
Almost certainly if your vacuum is otherwise operating correctly but not picking up it will be either a blockage or a broken belt. The belt is super easy to check, turn the machine on and put it in normal operating position and tilt the head so you can see the roller. If it is not spinning it is going to need a new belt.
The blockage is a different matter and you will need to test suction at the hose, then the front to figure out where the obstruction is to be able to remove it. If you need more help please provide the model and make of your vacuum.
Regards Alec
If you need vacuum parts in Australia click here.
May 23, 2012 | Hoover Tempo Widepath Upright Vacuum -...
Trying to register my shark vaccume cleaner.
This site won't do anything for you
It is a social web site or forum
You have the make,model etc, try the
company web site,then call them & ask
your questions
Jul 04, 2011 | Vacuums
Have a kenmore cannister vaccum, brush is working but it is not picking up anything the suction is not working ?
Remove the hose and clear any obstruction from inside of it. If that does not work check the bag and filter if one is installed
Jan 26, 2010 | Vacuums
My new vaccum wont pick up cat hair
i would return this vacuum while it is still under warranty.
Aug 22, 2009 | Vacuums
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
I have a handheld vaccum that has quit picking up anything I try to clean
I've cleaned out the vaccum, now it's working, but thank you
Sep 28, 2008 | Dirt Devil Vacuums
Dirt devil dual cyclonic bagless vaccum
Did you check the hose and the inlet by the brush roll for a clog?
Feb 16, 2008 | Vacuums
Weak pick up power
that's true!!! you've take that for granted because metal strips such as the hair clip will tend to deteriorate the engine power. Since the turbine of your vaccum cleaner uses dynamo to provide for spin and it has supply electromagnetic charge. Since there's a metal that has picked up, it will absorb the magnetic power of dynamo causing your engine to malfunctioned step by step.. Better check the engine to a liscensed technician to repair the problem.
Jan 28, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Dirt Devil CE6000 Featherlite Wet/Dry Vacuum Logo
123 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Nick Olsen
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
