Question about Swiss Army Wenger Sportedge Bracelet Watch
I am unable to set the date on my model 79131
Has no leap yr. went from 2/28 to 3/1 cannot coordinate time
  • Auto Calendar (pre-programmed until the year 2039)
that means, you need to set up correct year in order to show leap years.... and then it will show you also correct day, after you will set it up correctly..... http://support.casio.com/storage/en/manual/pdf/EN/009/qw1545.pdf
check page 2
Mar 02, 2016 | Casio DW-5600E-1VCT Wrist Watch
I am unable to change the date on my Timex Indiglo. It currently reads (Sept.) 31, altho it is (Oct.) 1. How do I do change it without changing the time?
mcdevito75 here, If your watch is push button, simply push MODE and see the display flashing, then press mode again until you reach the date, then press set to set the correct date, then press mode again for steady display. If it"s a windup, simply go thru the 24 hour cycle for the correct date.
Oct 01, 2010 | Timex Watches
Unable to reset brietling colt, even after ajusting stem to 1st and 2nd postions.
mcdevito75 here, Let"s hope your description of the problem with your watch is wrong. Try this sequence, First, wind your watch, the automatic continues to wind your watch when you where it but to get it started, wind it 20--30 times. 2nd, your crown locks down, turn the stem Clockwise to un-lock it (the stem) now pull the stem all the way out then back in 1/2 way to set date. Set DATE to DATE before the real date turn crown counterclockwise. Now pull out crown all the way and turn clockwise to set the DATE and time (real Date) push the crown back in and turn counterclockwise to lock the crown. If this doesn"t work, look for a small watch repair shop in your area for this adjustment.
Jun 28, 2010 | Breitling Aeromarine Colt Ocean A64350...
Date changes at 1:00 instead of 12:00.
Many mechanical watches take several hours for the date change to occur. You might see it start at 11pm and finish as late as 3pm. This is not a defect but simply a characteristic of the mechanical movement. BTW, never adjust the date between 7pm and 2am as doing so can damage the movement.
Apr 16, 2010 | Watches
Unable to set the dual time on my new watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to B&M watch manuals.Rate me, please
Mar 16, 2010 | Baume Et Mercier Hampton Classic Square...
I have a Tommy Hilfiger analog watch with date. There is only one control to set the time but I would also like to set the date as well but am unable to.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to TOMMY HILFIGER watch manuals. Rate me, please
Mar 10, 2010 | Bulova Watch
Unable to set the date on an ESQ Gentlemen's Quest Big date
pulling the stem to the first click adjusts the date and pulling it farther adjusts the time. pull the stem one click and turn counterclockwise to adjust date. push stem back in after correct date is displayed.
Jan 05, 2009 | ESQ Quest 07100901 Wrist Watch
Can't seem to get AM & PM set properly
Had Pulsar analog watch. Couldn't set either day or date properly due to being unable to signify AM or PM. When days changed one or the other would be 12 hours off.
""googled" adjusting Pulsar watches" and found site which explained how. You set day of week and date to previous day and date and then move watch time ahead until day and date are correct. Then set watch time. Seems to work.
url: www.pulsarwatches.com.au/manuals_pdf/94_1.pdf
Apr 22, 2008 | Watches
Swiss Army Wenger Sportedge Bracelet Watch Logo
501 people viewed this question
Top Swiss Army Wenger Watches Experts
Ansel Alberto
Ansel Alberto
Michael Vincent Cruz
Are you a Swiss Army Wenger Watch Expert? Answer questions, earn points and help others
