Question about Poulan "Poulan" Push Mower
My bolen push mower won't start, it worked two weeks ago. Gas and oil are full. where do I go from here, change spark plug?
  • 64 Answers
See if it has spark. try to trickle a little gas into where the carburetor is and see if it will atleast fire.
Posted on May 01, 2010
2009 190cc Briggs starts but won't run
Ensure the oil is full. It has an oil low sensor. 30w oil.
Jun 13, 2013 | Toro Garden
Bolens 4.5hp mower won't start
did you hit a rock? and shear the key that times the flywheel to the crankshaft check for spark the coil might have failed
Jul 01, 2012 | Briggs & Stratton Briggs Stratton...
One year old bolens push mower, 550 series B&S
How is your compression? If it is low, your piston rings and/or the cylinder walls could be damaged and pulling oil up to the combustion chamber, which will burn oil and foul the plug. If you overfill the oil you could possibly get this also. When was the last time that you changed the oil and/or put oil in it? Do you currently have proper oil level?
Sep 06, 2011 | Briggs & Stratton Garden
Turned mower on its side and changed the blade and now the pull rope is very hard to pull..its almost like the motor is locked up..I checked the shut off linkage cable,removed the spark plug, removed the...
Your piston cylinder is partially full of oil and/or gas. Take the spark plug out and pull the rope four or five times to blow everything out of the cylinder. If it's still hard to pull over with the plug out check the oil level in the crank case to see if it filled with gas while the mower was on its side. Make sure the plug is dry and clean and reinstall it. When it starts it's going to smoke a lot until it cleans out the cylinder.
Sep 15, 2010 | Poulan "Poulan" Push Mower
I just had my mower out and it ran on the first run in 3 weeks
I typically do 6 things in this situation:
1. Verify that the gas tank is full and closed
2. Verify that the oil is filled to the "full line"
3. Remove and inspect air filter clean/replace if necessary
4. Remove and inspect spark plug clean/replace as neccesary
5. Apply warm air to engine block via hair dryer at the spark plug for 5 minutes and attempt to restart
6. If that doesn't work allow the mower to "rest" for 30 minutes and repeat step 5.
Oct 26, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Lawnmower wont start
Are you getting spark first of all. If you are getting spark do you have good gas? If you have good gas most likely your carb needs some attention maybe you had some old gas sitting in there and something inside is gummed up it might need cleaning.
Sep 19, 2009 | Poulan "Poulan" Push Mower
My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Aug 08, 2009 | Garden
My lawn mower doesn't start and when it does, smoke comes out of exhaust
you may need to change the oil and/or empty the old gas and replace it with new.
This thing happens when you don't take care of your lawn mower for too long.
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Poulan "Poulan" Push Mower Logo
655 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
