Question about Boating
Need wiring diagram for a suzuki dt60 1983 tirm relays . Got new relay but must have wires back wrong. its the four pin type. Thanks
SearsTechToo
  • 261 Answers
SOURCE: GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Posted on Oct 03, 2008
SOURCE: automotive wiring diagrams
Thanks for suggestion autozone for wiring diagrams!
Paul
Posted on Nov 02, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Need link to 1998 isuzu rodeo relay/fuse diagram
http://www.bulldogsecurity.com/New%20Wires/New%20Wires/Wires/isurodeo96-03.htm
http://images.google.com/images?q=1998+isuzu+rodeo+electrical+diagrams&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&ei=5h6gSbHpEYKEsAPjwIDHCQ&sa=X&oi=image_result_group&resnum=1&ct=title
HEre are two different links hope they work for you
Posted on Feb 21, 2009
  • 5681 Answers
SOURCE: Need to know year of this outboard
Go to the Search, type in suzuki dt60, there will be many items to help. Its between a 1977 and 1984. Some of your numbers are serial #s and you can probably use the #6001 or the second number to be more exact.
Posted on May 04, 2009
yotaguy
  • 232 Answers
SOURCE: need wiring diagram
Go to autozone.com and register they have good wiring diagrams for your truck.What I saw was all the relays going to ground so you should have 12V coming off the ignition switch.
Posted on Jun 01, 2009
2008 Suzuki Boulevard C90T accessory wire location
Hi, Dave for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Suzuki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
HOW TO Wiring new accessories through RELAY Suzuki Volusia Forums Intruder...
2008 Suzuki Boulevard C90T accessory wire location Google Search
Suzuki Motorcycle Wiring Diagrams
Suzuki VL1500K5 Supplementary Service Manual
https://www.partsfish.com/page/oem-parts-for-suzuki
http://mybikemanuals.com/suzuki
Suzuki VL1500 Service Manual
Mar 10, 2018 | 2008 Suzuki Boulevard C90T
I have a 2006, Suzuki 750F , I put a new battery in the wrong way :. It sparked and now it wont start, what did i burn out please help me :. johnny angel :.
Ur first check up would ur fuses fusible links as wire and move on to electronics hoping you would resolve with just a fuse or fusible link. Good Luck
Dec 22, 2016 | Suzuki Cars & Trucks
How do I wire a 5 pin relay
That question is of no use to us- to be able to answer it
What Type 5 Pin Relay ?
Wire to what & why ?
Obviously-- if your building something for a vehicle,
you have know the answer, or have a wiring diagram,
if your tying into some circuit, for the control side of the relay
Like 98% of all the questions on this site, everything is a secret
Nov 06, 2014 | Cars & Trucks
Need headlight wiring diagram for 2013 Kia Rio,want to fit spotlights
you will have to fit a relay into the system. Tap a wire into the high beam power wire for the headlights. (Piggy back connection) take this wire down to the fitted relay to a coil pin on the relay. connect a wire to the other coil pin of the relay and return to the dash area to an control switch through it then to an earth point.. Run a wire to an inline fuse directly from the battery ( fuse close to the battery as it is a high current line) down to one pin of the relay. connect up the power wire for the light to the opposite pin on the relay and connect the earth wire of the light to an earth point
According to road regulations you cannot have spot lights on by them selves and they must only operate in conjunction with high beam operation.. The setup as I describe allows you control of when the spotlights will be on ( switch in the dash) and if on will be extinguished when low beam is selected as per regulations. The relay ensures that the trigger wires do not carry full light amperage so light gauge wires can be used and only the power wire from the battery to the relay to the light need to be heavier gauge.
Sep 11, 2014 | 2013 Kia Rio
My 04 suzuki katana 750 has a battery draining problem
You definitely hooked something up wrong. Get a wiring diagram for the exact bike you have and try again. Oh, the regulator is probably fried. Sorry.
Apr 03, 2014 | 2004 Suzuki GSX 750 F (Katana)
2000 chevy silverado 1500 4.8 4wd will not start
Your pump is controlled by the pcm using a 12 volt signal to the relay. Pull out the relay and probe the relay socket with a voltmeter. There should be 2 terminals with 12 volts when the key is on. With the key off, there should be one 12 volt terminal coming from the ecm b fuse. See top left of diagram below.
Jul 15, 2017 | 2000 Chevrolet Silverado
Mito relay pins cant match them up
Hi and welcome to FixYa,
Would the 5-pin relay be for the starting controller of a Cagiva Mito? If yes, perhaps the diagram below would be of help to locate where each wire (color) goes to what pin.
Good luck and thank you for asking FixYa.
Dec 21, 2009 | 1997 Cagiva Mito 125 Evoluzione
Headlight/turn signal problem
RELAY, NOISE SUPPRESION/is 1323592 its black and mounted under the hood on the shock tower, check page 4 and page 16 under LHB230FT in your book(item 464) ? why are you messing with this relay if you have a light problem ? does left turn signal stay on with key off /with parks only /with head lights /both front and back turns or front only? have you removed both frt and back bulbs together and ck voltage in sockets ?/wrong bulbs? i would need more info
Sep 01, 2008 | 1987 Volvo 760
Boating Logo
148 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
