Remove shipping lock from black cartridge. (cc530a)
HP black cartridge cc530a
brett207
  • 231 Answers
SOURCE: Just installed new CC530A black print cartridge in
Was this a new genuine HP cartridge, or refilled 'remaunactured one?
Replace it again.
Posted on May 11, 2010
chanddra2009
  • 615 Answers
SOURCE: HP 2320 problem
For Every New Catridge there is lock on catridge head u must remove to use the catridge...take out the catridge then remove the shipping seal or lock. refer instruction printed on catridge cover.
Posted on Jul 07, 2009
SOURCE: Please remove shipping lock from yellow cartdrige
I had same problem and googled it and found this solution
As per above I have swapped the cartridges around
Firstly the message "Magenta in wrong place" came up but
I persevered and swapped around again and after a loooooonnnng
initialization IT WORKED and started printing
Clearly its just something HP have to stop people using compatibles which I guess it qutie common and designed to make you give up and pay the much higher price for originals
Thankyou to person who put this solution on !!!
Posted on May 21, 2010
elix0411
  • 3530 Answers
SOURCE: 2025 HP color laser. I
Welcome to Fixya
Try to restore the printer back to the fatory default state.
To perform this function, use the controls on the top of the printer:
Click OK
Arrow over to the Service menu
Arrow over to Restore Defaults
Click OK
The printer will reboot itself and go through a few minutes of initializing/calibrating, and the error will no longer come up.
Thank you for using Fixya!
Posted on May 25, 2011
  • 304 Answers
SOURCE: Part number for the OPC
That OPC is the same for HP CP1215/1515/1518/2020/1525 CM 1312/2320/1415 cartridges.
No Part number, search OPC HP CP1215/1515/1518/2020/1525 CM 1312/2320/1415.
Posted on Jul 04, 2011
Hp cp2025 remove shipping lock
I had same problem with black and blue cartridges. I did all recommendations -- return to factory setting ( no help). Shake cartridges REALLY hard ( no help); reinstall printer/ driver ( no help). What finally WORKED was SWAPPING the cartridges around ( for ex. put red in black spot, blue in yellow). I then got an error message ( b/c in wrong spot). Then I placed them back in correct spots and it WORKED !!! NO more error message that the ship lock was on !!! And this worked with generic cartirdges.
Nov 19, 2011 | HP Laserjet Cp2025n Printer
HP 2025N PROBLEM REPLACE THE SUPPLY BLACK ONLY
Put a new black toner cartridge (CC530A) in your printer.
Jul 14, 2011 | HP LaserJet 2840 Printer
I have a HP Color Laserjet 2025. I recently replaced the color cartridges and when I tried to replace the black toner cartridge I got the message - "remove the shipping lock on the black toner...
My suggestion is to put the 2 cartridges next to each other and look at them as closely as you can. There has to be a difference between the one that works and the ones that give the error.
Something that just occurred to me. Check the slot where the black cartridge sits. Check it for something that could have fallen off the original cartridge and is wedged in the slot. Compare the slot with another cartridges slot.
Because one cartridge works and others don't, it tells me it's a physical(hardware) problem not electrical.
Jul 07, 2011 | Office Equipment & Supplies
Part number for the OPC Drum in a HP toner cartridge CC530A.
Jul 04, 2011 | Office Equipment & Supplies
Hp cm2330 remove shipping lock
HP Color LaserJet CM 1312 Series MFP customers may experience a failure during initial printer startup. After installing the print cartridges and powering on the printer they may receive an error condition or error message on the printer’s display. The printer’s orange Attention LED will flash and a Remove shipping lock from XX cartridge message will appear on the printer’s display; where XX represents the black, cyan, magenta or yellow print cartridge or any combination.
SOLUTION: First, verify the print cartridge shipping locks (orange ring attached to the toner as shown below) have been removed from the print cartridge(s) in question. Second, verify the front and back doors of the printer are properly closed. If the shipping lock has been removed, all doors are closed, and the Remove shipping lock from XX cartridge error remains a unit exchange is the recommended solution.
Contact Hewlett-Packard Customer Support. Refer to your warranty/ support documentation for the number to call in your area. Refer to this document’s number (c01677135) with your customer service representative.
Hp tech support phone for this model # : 1 800 334 51 44
Or you can take the printer to an HP Authorized Repair Center, heres a link will help you find one near your location:
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
You can contact me directly on:
eliteprintersolutions@gmail.com
Jul 15, 2010 | HP Laserjet CM2320nf All-In-One Color...
HP 2320 problem
Jul 07, 2009 | Office Equipment & Supplies
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
1,604 people viewed this question
jasbo
jasbo
