Question about Keurig B50 Coffee Maker
My neighbor?s house was hit by lightning. My Keurig machine was plugged in and now won?t work at all. Is there a fuse/breaker/reset button?
    Sniper:
  • 92 Answers
..um... there might be a Movister a metal oxide Resister that may have taken the hit...but there is a electrical panel in the unit. the b-70's electrical unit is on the right side lower area... covered by the black shroud.
no breaker... that's for sure...
It could be as simple as a circuit board trace blew... acting as the fuse when the Movister took the jolt of the lighting hit... so it may be fixable.
just the realitty of opening up the unit... and your willingness to open it and look...
you can re-submit on how to open the unit...
I have an answer on how to open up a B-70... should be similar
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Posted on May 06, 2010
Hydro Rain hrc 100 says NO AC
Could be many problems with a description as vague as "not working." Can you be more specific? Does no water come on? Does the timer say it is operating? Is it plugged in? Does outlet have power? Are wires connected correctly? Can you start a zone using the bleeder screw?
Mar 28, 2014 | Orbit Hydro-Rain HRC-100-04-NA 4 Station...
Titan Troubleshooting
Check for small fuse on circuit board:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Water heater circuit boards are NOT protected from surge. And reset button does not protect from surge. Nearby lightning can put out any household appliance, especially since more of these things are electronic instead of mechanical.
Install single-use whole house surge protector and replace it after each surge event instead of replacing appliances.
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
The quickest solution for tankless is to replace whole thing with more reliable tank-type electric heater for $275 from local box store.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 18, 2013 | Water Heaters
My Keurig # B70 won't turn on
Try another outlet, check fuses, or breaker box.
Sep 08, 2012 | Keurig B70 Platinum Brewing System
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
Samsung tv lightning strike reset
It is likely the ac fuse which the power cord goes directly to got hit.
back would have to be removed and fuse checked.
Mar 18, 2012 | Samsung Televison & Video
Where is the reset button. Our washer won't go on. It has no power at all.Tried the circuit breaker..Machine was here when we bought the house
Thanks for choosing FixYa Karen and welcome. You can unplug the washer for 30 minutes and plug it back up to reset the washer. Make sure the outlet works. Next, check your power cord. Wigglle it while plugged in to see if the power comes on. Inspect the cord first for damage before you do that. If the outlet, breaker, and cord is good, you need to check the fuse to the washer. If it still has no power, you may have a bad control board. Due to the fact there is no power, it is probably electrical. Inspect all wires in the washer for damage. You may need a voltage meter to test for power in the cicuits.
Aug 28, 2011 | Washing Machines
My parents had a close lightning strike and now their washing machine (Maytag A9200) doesn't work. Is there an internal fuse or something? we are hoping this isn't a total loss.
First check the main circuit panel to verify that the breaker didn't trip. Sometimes with double pole breakers, you'll get half of it tripping (even with the tie bar that connects both halves).
Make sure you flip the breaker all the way OFF and then turn it back ON, that way, a partial trip will get reset. Just turning a breaker to ON after tripping, won't reset most breakers,
I would find it unusual for only the washer to have taken a hit so try the above and let me know if that resolves the issue, or if you have any other damage from the storm.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Washing Machines
Sears Craftsman Gar. door opener won't respond
There isn't a fuse. You are going to need to remove the cover on the opener and find out where you are losing the power. Maybe a neighbor has a volt meter you could use. I would check the power cord and then the logic board. Makes no sense but I would check for burnt or missing traces on the printed circuit board especially around that small transformer.
Aug 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I unclog the copper line?
The copper line and the pump. Which is the concern?
On the circuit breaker, Turn it off and in five minutes, back on.. Then check the outlet at the cooler to see if it's getting power.The copper water supply line? You do have water to the float control valve? or no?
Jul 10, 2009 | Heating & Cooling
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
Keurig B50 Coffee Maker Logo
328 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
