Question about Husqvarna Chain Saw 20" Bar
Chainsaw quit cutting well, the bar gets half way down in a log and it quits cutting, the engine even starts to choke down
  • shawn clarke May 11, 2010
    what brand of saw is it? does it cut straight?
    Brigadier General:
  • 4,088 Answers
Remove the bar and chain--check the oil port in the side of the engine case where the bar fits up to. Start the engine--oil should ooze out of the port. If not, service the pump, lines and tank filter. If oil does ooze out, clean the chain groove, and the two oil passages that feed oil to the groove. If the outsides of the chain groove have flared out from chain wear, file these edges off (about 45 degrees) til they don't project beyond the bar vertical surface so that they don't catch on the kerf cut. Make sure the chain is being sharpened and adjusted properly. The 'choking down' may be from the engine overheating while trying make the cut. The engine should 4-stroke when running at speed, but immediately 2-stroke when cutting. Make sure the air cleaner and muffler are not plugged. Hope this helps!
Posted on May 04, 2010
Bar might be bent, rakers between the cutting teeth need filed down or one side of chain is sharper than other
Posted on Apr 10, 2013
Husqvarna 223l starts but quits before I can even get the choke off, then will not even start again. Has been great until this.
I can assure you it wont be leaking oil, as the only oil it uses is mixed with the fuel.
Lock throttle trigger on,
Start on full choke till it fires,
Switch to half choke and it should fire up on high revs,
Blip the throttle and it should turn to tick over.
If it still keeps cutting out it could point to a carb or fuel takn issue.
Aug 04, 2012 | Husqvarna 223L
Chain saw quits at full throttle unless it is half choked
Check the fuel filter for plugging. Has the H jet needle been changed? If so, turn it CCW until the engine 4-strokes at speed with no load, but immediately 2-strokes when cutting. Make sure you have fresh fuel mix in the tank. Hope this helps!
Nov 19, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Bought a Poulan Wild Thing 18" gas chainsaw (P4018WT) secondhand from someone who only bought it to cut down 3 trees. It will not start. I know that it works, as the guy started it up and showed me how...
Don't prime it 6 times.
Prime it once and try starting. Keep trying with one prime.
If that doesn't work, let it sit for a bit. And then prime it two times and try starting again.
If that doesn't work, try priming 3 times.
Then try half-choke with one pull only, and then move choke to run for the second pull.
The saw might have an on-off button
Oct 15, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Husqvarna Model 136 chainsaw will only run for a short time with choke closed. Engine quits shortly after choke is opened.
Take apart the fueling system and carb. Something is blocking or gummed up. One thing that sometimes works is to remove air filter, rev the unit up, and place hand fully over the intake, and remove before unit stalls. This sometimes will clear the blockage.
Oct 05, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chainsaw starts then quits right away. half choke. has fuel and bar oil chain is free and runs.
Our mini-Mac saw seems to require some fiddling with the choke as it doesn't have a primer button, but once it starts firing, the choke can be opened fully after a moment or so. Check the fuel filter, air filter, and muffler for plugging. Check the fuel line for decay or other problems. Make sure the carburetor fasteners are tight. Check the spark plug for blue, snappy spark (gapped at 0.020"). Hope this helps!
Aug 16, 2010 | McCulloch Garden
Engine starts runs rough,then quits before you can put a load on generator,starts with half chock,will not run without half chock,and even half choke runs rough,and then quits
this is down to fule shortage strip card and all fule pipes clean the tank on off tap and any filters fitted also check all the jets inside the carberetor blow out with comprest air,,,dont go pokeing wire into any jets!! that could wreck the jet, but its all down to fule shortage
Jan 23, 2010 | Generac 5622 GP Series GP5000 6,250 Watt...
I own a McCullogh 610 Pro mac chain saw. Why does
Check the muffler to make sure that the spark arrestor screen is not plugged. Make sure the air cleaner is clean and not plugged. Turn both L and H mixture screws CW to stops (lightly), then back out 1-1/2 turns each. Warm up the engine, then open the throttle and turn the H needle CW until the engine speeds up, but still '4-stroking' but should immediately start '2-stroking' with light cutting. Release the throttle and adjust the L needle CW for fairly smooth idle, yet rich enough to allow the engine to 'follow the throttle' immediately when accelerated. Adjust idle speed CW until the chain starts to turn, then back off until it quits turning. Make sure the chain is being properly oiled and is adjusted for no chain droop, yet turns freely by hand. Hope this helps!
Dec 27, 2009 | Garden
262 XP engine cut out on tickover, now will not start
Try checking for spark when she won't start. I'll wager your ignition module quits when it gets good and warm. HTH
Lou
Sep 28, 2009 | Husqvarna Garden
CHAIN SAW QUITS CUTTING AS IT HITS WOOD.
The make, model, and occationally the serial number help us solve your problem.
Does the engine quit running? (Carburator needs adjustment)
Or does it continue running and chain stops? (need clutch refaced or replaced.) (to aggressive a chain for the size of the engine)
I think you replaced parts unnecessarily. Maybe quicker and cheaper to visit your friendly neighborhood chainsaw shop. A good one can repair it even if they do not sell your brand.
HTH
Lou
Sep 09, 2009 | Homelite Garden
Stihl ms-250 won,t start , and gas leaking from under the exhaust manifold , also plug seems not to be spaking even when dry . every time i try to start engine it floods . ?? the saw is only 3 mths old ....
You may need a carb rebuild kit. they are thin rubber diaphrams and will harden up and warp if not used regularly or if the fuel is improperly mixed.
These are easy to flood if you pull them too many times on choke. Pull it on HALF choke until it pops. then turn the choke off, into the run (I) position and pull it until it starts.
If it's flooded, remove teh plug under the cover, blow off the sparking end and pull the engine a few times without the plug. this will empy the cylinder. WATCH YOUR EYES!
Jul 03, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Husqvarna Chain Saw 20" Bar Logo
211 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
