Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Where is the defrost timer on a GE model gss20iemb ww
    President:
  • 1,218 Answers
Good day,
Doesn't have one. It functions thru a motherboard mounted on the bottom back rear of the machine.
Normally 5 thermistors are used (3 in the freezer 2 in the fresh food compartment) to operate the machine.
Defrosting cycles are controlled by the motherboard with the input as well from compressor running time and the number of door openings.
Posted on May 01, 2010
Where is the defrost timer located on model GE GSS22JETG WW? This is a side by side
USUALLY LOCATED IN THE FRIDGE AT MIDDLE TOP BUT SOMETIMES CAN BE FOUND IN THE FREEZER ALONG THE WALL
Mar 08, 2015 | GE Refrigerators
Where is defrost timer on model DSS25JFPA WW
IT DOES NOT HAVE A DEFROST TIMER EVERYTHING ON THIS UNIT RUNS OFF A MAIN BOARD
Jan 16, 2013 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
How to locate and replace defrost timer on GE GSS23KGSA WW
Yes the GSS23KGSAWW defrost is controlled by the WR55X10942
motherboard. What is happening that you would ask about a defrost timer? Let me know if you have questions, Thanks Sea Breeze
GSS23KGSAWW Service Manual
Nov 19, 2012 | GE GSS23KGS Side by Side Refrigerator
I have a G E model gss20iemb ww I'm looking for the thermistors and how many are there I found one and I know it is bad
One at the top of the refrig section , one in the middle , and 1 at the top of the evap coils , and 1 at the bottom of the evap coils .
May 01, 2010 | GE Refrigerators
GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model # DSS25PFMD WW, lights and fan are working not cooling
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
Fridge warm at top cold at bottom
If the fan is no coming on inside the freezer this will need to be fixed soon. Both fans upper and lower must run while compressor runs. Inside the fresh food compartment close the damper on bottom left side next to the paned drawer. If this does not help send more cold air to the top let me know as there could be something else causing the dampers not to open and close properly.
Thanks, Sea Breeze
May 28, 2009 | GE Refrigerators
Defroster cycle stuck
Unfortunately GE has been having a problem with the main mother boards on your model refer, the mother board controls the defrost cycle and there is not reset for it, you may have a bad board.
Mar 17, 2009 | GE GSS20IEM Side by Side Refrigerator
Coils ice up
appears to be the defrost timer,unit should have advanced out of defrost within the time you listed
Jul 17, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
304 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
