Question about GE Dryers
Heating element inop. and the unit is brand new, 0 hours.
  • 1 more comment
  • special_k198 May 01, 2010
    Thank you for the reply,
    The dryer does operate, the unit is brand new that was given to me never used. I am getting 220v at the cord terminal at the bottom of the dryer. It spins and the blower operates properly. I just have no operation of the heating element, ie. The dryer does not heat.
    Regards,
    Robert
  • special_k198 May 02, 2010
    Good evening,
    Thank you for your assistance, I did some testing with my DVOM a found one leg at only 30 volts, I traced the circuit to the circuit breaker and found it would intermittently show 120 volt then when a load is placed on it from the heating coils it would drop to 30 volts. I'm going to head to the Depot tomorrow to get a new breaker and give it a shot.
    Regards,
    Robert
  • Stephanie Kern
    Stephanie Kern May 11, 2010
    You say heating element is in opperable? Does the dryer still run? And if so it doesn't get hot at all?
    Problem Solver:
  • 3 Answers
Here's a tip on checking the high-limit switches:
Go to http://www.geappliances.com under the "services and support" tab select "Parts and Accessories" scroll down and enter the model# of your dryer, then click the arrow.Select the right model # and click on it.In the first box, select "Cabinet and Drum"and click go. Now scroll down to the "thermal-limiter" and "thermal safety" note the 4-digit number after each one of them. Then scroll back up to where the red underlined "click here to view diagram of Cabinet and Drum", and click it. Look on the diagram for the 4-digit number(s) and thats where they are located. Check to see if there are any burnt looking places where the wires connect to them. Also you can test them. If one(and/or both need to be replaced, go back to the page where you noted the 4-digit number(s) and the following # is the part # (example: WE4X757 or WE04X10094). Then just buy and install the part. Now try it and see if it gets hot.
Posted on May 04, 2010
Hey there, I have a Westpoint NOFROST De Luxe Tropical frige, model # WRK 297.1. The freezer section is forming ice and the circulation fan is making alot of noise due to ice being formed behind the back...
I believe your problem is the defroster circuit . There are only three components on most refrigerators unless you have something real special . Kidding . They are as follows : defrost timer , heating element , and defrost cut out switch . The defrost timer cycles the refrigerator out of normal operation and into defrost mode once every six to eight hours depending on the unit . When in this mode everything shuts off , compressor , circulation fan , and condenser fan is so equipped . To eliminate the circulation fan , you'll have to keep an eye on your refrigerator checking in every half hour or so for six hours to eight hours and see if it stops working . If it does , then we know the timer is working correctly and the problem will be the heating element or cutout switch . The heating element is checked with an ohm meter. Usually they burn out when they go bad and you will read infinite resistance. The defrost cutout switch should read 0-1 ohms when the freezer temperature is 40° F or lower. If the heating element checks good , in other words it shows to have resistance usually between 30 and 100 ohms, replace the cutout switch . If the circulation fan never shuts off and the unit continues to run without shutting down after a six or eight hour Time cycle , replace the defrost timer . Good luck
Feb 22, 2011 | Refrigerators
New Rheem electric 50 gallon not heating
Check the elements, if you have access to a meter to check them. If they are getting power to elements and you have no hot water.
The elements are not working correctly. I had some elements check out ok till the thermostat's turned on and the elements didn't heat.
Sounds like the elements are bad.
Jun 01, 2010 | Water Heaters
Brand new 2.5 gallon water heater will not heat water.
sound's like it is the element.place a continuity test on element ,and see what you get
Apr 21, 2010 | Rheem 81VP2S 2.514"9-3/4"22
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 15, 2009 | GE JBP30 Electric Kitchen Range
Coffee urn heating element not working
there are 3 or 4 componants inside that could cause the problem.
if you can use an ohm meter, check all of them for continuity.
a switch
overtemp fuse
perk control fuse, or keep warm fuse
element
all should read "short " or almost 0 ohms when the unit is unplugged '
Dec 14, 2008 | Faberware 12-55 Cup Coffee Urn
Inoperative oven electric elements
It could be contact problems where elements are pushed into in oven. Elements are usually plugged into heavy copper lugs at the end of both element ends. should look at manual for this unit to see how to remove and check for blackened ends. {Make sure to unplug before any work}
Nov 28, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
My whirlpool LER2614EW2 DRYER WOULD NOT HEAT
do you have a voltage meter?? if so with the back off and the unit running on high heat check the voltage at the heating element if 0 volts unplug unit and lookup the left side of the element casing and you will see a thermal fuse check to see if it is good it should be closed across the terminals it is the size of a nickel or so. you can jumper it out to see if the element is good If it is bad the part # you need is a 279769 which includes a new hi limit stat NOTE*** this is a one time thermal fuse the main cause for this to blow is a clogged up vent system so check your vent and clean if needed
Nov 17, 2007 | Whirlpool LER5636P Electric Dryer
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dryers Logo
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
