Question about Waterway Above Ground Hi Flo Pump
The pump trips when plugged in, it sounds like it trys to come on. We don't have the manual to trouble any problems
I have the same problem. Started Wednesday after a power outage. Any reults?
Posted on May 28, 2010
Fisher and Paykel Smartdrive GW703-U, wont go into spin, trys but pumps a bit of water out make a noise & thats it
It could be a blocked pump, it could be a faulty pump.
You can find the service manual at the following link and it will help find the exact cause of the fault. Download the smart drive service manual.
Link:
Mar 08, 2012 | Washing Machines
I have an Admiral LNC6760B71 model and it just quit working (lost power). We checked the breaker and it was tripped so we fixed that and also plugged it into a different outlet just to be sure, but still...
A leading cause of that is the drain pump has seazed up.When it has seazed up the motor still trys to turn it but is having a real rough time,so it trys even hard to the point the motor overheats due to drawing excessive amprage where it ultimatly trips the circuit breaker.By getting to the back of washer if able and removing the small panel on right side and removing the clips that hold drain hose up to top of cabinet,the drain hose could be pulled through that small panel and holding it a low point the water in washer will drain by gravity, use a couple of buckets to catch water. After water is drained reinstall drain hose to where it normally goes,the washer could be tipped up so the control panel is resting on the wall, the drain pump will be on the right side,you could turn the pulley by hand and see if it turns easily,if any resistiiance or if the pulley doesn't turn at all,the pump& possible based on the condition of it the belt will need to be replaced.
I hope my answer will help you to resolve your washer trouble,
Gene
Aug 05, 2011 | Admiral Washing Machines
1992 Buick Century Custom. Trouble starting as though not getting gas. Changed the fuel pump and filter and still has the problem. After a few trys it will start and run ok. ?????
Sounds like you need to replace the fuel pump relay which is about $13 at Autozone. It is simple to replace. It is under the hood on the passenger side right behind the headlights.
Oct 11, 2010 | 1992 Buick Century
Mechanical difficulties
sounds like a clogged fuel filter or a fuel pump that is not delivering enough volume .. they had some trouble with fuel pumps about that year but not sure on the f150 .. if you let the fuel level get too low then it would overheat and damage the fuel pump ... here is instructions on testing the fuel pump.:
http://www.ehow.com/how_5061273_replace-fuel-pump-ford-f.html
Feb 22, 2010 | 1992 Ford F150 SuperCab
Dishwasher fills with water but when it should start washing it sounds like the pump trys to start and trips out, this happens over and over while still filling. any ideas?
Hiya,
without the make and model number its hard to tell exactly what the fault is,
Generally this is caused by a siezed motor, could be something got into the impellar or worn out.
When you say trips out, do you mean electrics trip?
If so, you have probably had a leak in the base of the appliance and shorted the motor.
Hope this helps.
Regards
Sussex engineer...
Please rate my help.
Oct 22, 2009 | Hotpoint 24 in. DWF32P Free-standing...
97 chevy suburban 6.5 turbo only at 40 or below it trys to cut out ,when the engine temp. warms upon the it runs good new injector pump 30,000.ago and new glow plugs last year with control box if sets over...
It sounds like your some of your glow plugs may be burned out or the glow plug system may not be cycling like it should. Pick up Haynes Diesel Engine Repair Manual, part #10330 at your auto parts store and it will walk you through diagnosis and repair easily and inexpensively.It costs about $20. Hope this helps.
Oct 13, 2009 | Chevrolet Suburban 1500 Cars & Trucks
1990 Honda Prelude won't start after I stop or konks out during
Sounds like it could be a Main Relay (with controls the fuel pump & others). Look it up - on the '92 models its under the dash near the steering column.
Apr 06, 2009 | 1988 Honda Prelude
Waterway Above Ground Hi Flo Pump Logo
110 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
