Question about Breville VHB012 2Speed Handheld Blender
My breville hand mixer, model vhb011 just stopped, while using it . Any ideas, changed the fuse and checked the plug grip.
I have a breville kinetic blender - not used for a while. Gives a nasty burning smell when used. Anything I can do?
Unless it is food stuck around the blender bottom , you have parts burning up inside. Its not safe to use. Check to make sure it is clean top an bottom if smell returns stop using. Could burn house down.
Jan 29, 2015 | Breville Blenders
How do i unlock the breville cbl25xl jug
Probably why it was got rid of. But if you have the manual check trouble shooting or contact manufacturer.
Dec 16, 2014 | Breville Blenders
The chopping mechanism, which should turn freely, is "frozen" & won't turn. not even manually.
I'm assuming that this isn't happening on an model in which the bowl can be detached - otherwise the plastic bushing has melted and glued the shaft to the base of the mechanism - it will have to be replaced. You can find one on the Breville site
http://www.brevilleusa.com/blending.html
select yours and you will find it in the Parts &Accessories tab.
The mixer has an plastic bushing on the shaft of the chopping mechanism that is there to connect it to the shaft of the motor. If that bushing or the bearing of the shaft got damaged in any way the entire mechanism will lock out.
To find out what exactly happened you will need to dismantle the mixer - take out the 4 screws on the bottom, unclip the power wire, remove the supports of the motor and pull it out for inspection. Parts from older models can be obtained only from a dealer, you will have to contact one and order it .
Jul 30, 2011 | Breville Blenders
Blender will not run. the power button is lite but
There is a 10 Amp thermal fuse (SF129E) that is supposed to create an open circuit when the motor windings exceed 133 C degrees. Although this fuse should close again when the motor cools down it can become perminantly damaged. Locate the fuse by following the black leads from the coltrol board to the motor brushes. It's inside a cloth insulating sheath secured against the windings with a metal strap and two ty-raps. I bypassed the fuse with a wire instead of replacing it. It would probably just blow again sooner or later. p.s. you need a T10 Torx screw driver to disassemble (screws under rubber feet) $3 at ACE hardware.
Jul 01, 2009 | Breville BBL600XL. 5-Speed Blender
Beaters
KitchenAid Turbo Beaters - Stainless Steel
Model: KHM2B
$14.99
Features:
Replacement or Extra Set of Self-Cleaning Stainless
Steel Beaters Mix Cookie Dough Easily.
Turbobeaters fit only Hand Mixers manufactured since
September 1997.
If you have a model produced before 1997 please call
the KitchenAid Customer Satisfaction Center at
1-800-541-6390 with the model and serial number from
your hand mixer for further assistance.
Mar 23, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Breville 600XL not turning on
My BBL600XL stopped working because of a blown fuse. You need to remove the phillips and torx head screws out of the bottom. Then remove the base. There you will clearly see a fuse on the circuit board.
It appears to be a 10A 250V fuse.
Jan 28, 2009 | Breville BBL600XL. 5-Speed Blender
Breville hand blender doesn't blend continuously
I have the same problem. Mine used to work, has only seen light use, and now it runs for about 1 second before it shuts off. Expensive POS. There don't seem to be any solutions either.
Nov 18, 2008 | Breville Cordless Hand Blender - Silver
Braun blender 4191 motor part does not work. fuse is alright. cannot open the cover in order to asess the damage. please advise.
My GF broke our Braun handheld mixer type 4191 500W, trying to mix some figs, the mixer doesn't do anything anymore. I like the mixer very much. I poked a while trying to open it and look what is wrong. This is what i found to open it. On the top, where the numbers are to adjust the speed: remove gently that lid. Below that you'll find 2e lid with the numbers on (1-5), this you can get open by pressing inside the 2 holes with 2 little screwdrivers, push these 2 black tips away and the 2e lid can be removed. Unfortunately i broke my mixer up trying. Now it's open i see how it was. Good luck guys
May 01, 2008 | Braun MR 5550 M HC + BC MultiQuick...
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
My hand mixer stopped working.
Have you tried greasing it near the blade. I read in my instruction book that sometimes they seize if they aren't used often. They also suggest trying to soak the wand in a pot of hot water for a minute or two and then trying to use it in the water. Hope this helps
Aug 30, 2007 | Bamix Gastro 200 Handheld Blender
Breville VHB012 2Speed Handheld Blender Logo
142 people viewed this question
Top Breville Blenders Experts
Mike
Craig Butler
Craig Butler
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
