Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Our GE Profile (Quiet Power 6) dishwasher is having trouble cleaning our dishes. The top shelf rarely gets cleaned and the bottom is questionable. It used to work fine. We always use Cascade powder detergent on a normal wash cycle. We have hard water. Any advice would be appreciated. I took apart the washer looking for an obstruction but none existed.
  • GE Master
  • 3,740 Answers
The obstruction can be external to the unit. Check the drain at EACH connection working backward from the sink connection all the way to the motor pump outlet hole. Do not forget to dis-assemble the Air-Gap (if installed) and to check the inside of the garbage disposal hole also.
If all of these areas are free of obstructions then there is a good possibility that the pump impeller is either very worn / broken blade or there may be damage in the pump housing itself.
I think that if you look at the external drain lines, holes, and connections you notice a big change in the dishwashers performance.
Noting that you have hard water.... I really don't like promoting products.. but when one works and works well I will pass that information along.
There is a product out there made by FINISH called Jet-Dry and it comes in a mini basket form:
http://www.viewpoints.com/images/review/2009/134/13/1242326145-55717_full.jpg
or an additive if you have a rinse dispenser:
http://www.finishdishwashing.com/rinse-and-drying-agents.php
Lastly.... if you need to clean up the dishwasher.. on an empty no dishes cycle add 2 cups of white vinegar when you know the cycle has just started filling NOT draining and let it wash. Then do your dishes after that cycle.
Thanks for using FixYa.
Kelly
Posted on May 01, 2010
Testimonial: "very good advice. Covered the full spectrum of possibilities. Much better than the manual. thanks "
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
Apr 14, 2016 | GE Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
Check whether the top rack spray arm main hose sits firmly into the
machine. If there is a leak in this area water pressure may not develop.
Also check the water pump in the machine!
Oct 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
GE Quiet Wash 3, top arm does not spin
It sounds like you don't have enough water. Your water inlet valve may be not letting in enough water or the plastic pump inlet screen located on the bottom of your dishwasher had something blocking it.
  1. Check to see if there is something blocking the plastic screen on the bottom of your dishwasher.
  2. When your dishwasher is in the final cycle add a pot of hot water to the dishwasher and see if your dishes come out cleaner.
If the dishes come out cleaner you may need a new water inlet valve.
Dec 29, 2009 | General Electric Adora GHDA670N Built-in...
My GE Eterna Series 3 Quiet power is not cleaning our dishes. Mostly the dishes on the top row has lots of stuff found in the glasses and mugs. YUCK!! I ran it for a minute and there is just water in...
I just took mine apart (bottom turntable, screen, etc.) and I was disgusted by the grime and gum that was clogging everything. I think it was keeping all the water a gritty white, which constantly left residue. I am currently running a load... hope that the "clean" dishwasher actually washes my dishes now!
Nov 18, 2009 | Maytag Dishwasher
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
GE dishwasher Quiet Pro 3 middle washing arm
Try unscrewing it from the bottom, remove it and give it a clean. If it is full of food it will not turn.
Check the funnel on top of the basket is free of food too.
Jun 10, 2008 | Dishwashers
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
2,918 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
