Question about Maytag Kitchen Ranges
I have a Maytag MGR5775QDS. the broler and oven use the same igniter and tube burner on this model. The broiler works fine, but when I use the "bake" function, the oven doen't heat up. The igniter doesn't glow I've already replaced the igniter, but still the broiler works but the bake function doesn't work. Please help.
  • 1 more comment
  • pieriep May 01, 2010
    I don't want to call Maytag. What are ther possible problems?
  • pieriep May 03, 2010
    No, there are no error codes.
    Assuming it is the clock / controller, can you tell me if it is difficult to replace the clock / controller? Can you offer any advice or instructions to do so?
    yes
  • 15,935 Answers
Are there any error codes?
Posted on May 01, 2010
  • blueextc3221
    blueextc3221 May 01, 2010
    In this case - I would point the finger at the switching bake relay on the controller itself. This part is also known as a "Clock"
    Seen HERE in the expanded parts diagram as part # 2
    CLICK HERE to see/order the Clock.
    CLICK HERE to order a tad cheaper.
    Please remember to accept the answer best helping you today - as if left un-Accepted, the first to chime in gets credit after 6 days - even if it is not an answer at all.
    Thanks for using FixYa!
  • blueextc3221
    blueextc3221 May 03, 2010
    Really - all you need is a phillips screwdriver.
    You can have it replaced in 20 minutes if you have never done it before.
    Disassemble/Remove the housing (by removing screws labeled 10 in the diagram supplied), unplug the clock, remove the screws (this one may have plastic pressure tabs) holding it in place.
    install the reverse of removal.
    Thanks!!
  • 1,284 Answers
Hi, if you have done the necessary thing which is replacing the igniter and the bake function is still not working, the best thing to do right now is to contact Maytag on as recommended by Maytag themselves..
1 (800) 688-2002 Canada
1 (800) 344-1274 U.S.
Take care
  • Shehu Pro
    Shehu Pro May 01, 2010
    Hi since you insist, check the control if it is working, check and see if any wire is burnt and finally remove the bake element and test it to see if it is working...
    Take care
Oven won't heat up when baking (Maytag MGR5775QDS)
Check the Manual/Auto Clock setting to be on Manual not auto . The Oven is waiting for the Right Time to start up .
Jun 13, 2012 | Maytag MGR5775QDS Dual Fuel (Electric and...
I have a maytag model # mgr5775qdw and the oven will not ignite. I know it is not the gas line as the burners all light, and the broiler lights as well. It is only the oven that does not heat. . .what...
This could be two possible problems. The igniter maybe bad, but doubt it. The igniter works both the oven and broiler, I believe on this model. The first thing I suspect is the switch in your wiring harness. The harness has a switch attached to it for each manifold. The switch for your oven maybe out.
Go to this site for diagram of parts: https://www.maytag.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20W10282172.pdf
Jun 18, 2011 | Maytag Ovens
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
I have a maytag pilotless ignition gas oven. the top burners work fine the broiler ignites fine. we just tried clean mode and its working too. the problem is we cannot get the oven to heat up. we turn bake...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 13, 2010 | Maytag Ovens
My oven stopped working. The top burners work,
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Dec 31, 2009 | Maytag MGR5775QDS Dual Fuel (Electric and...
My stove will not heat using bake but will work for broiler so I know it is not a heating problem. Help!
this model is not a dual fuel, and you do have a heating problem, there are two burners, a bake burner and a broil burner, both have ignitors. You have a bad bake ignitor.
Sep 27, 2009 | Maytag MGR5775QDS Dual Fuel (Electric and...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag MGR5775QDS oven wont heat.....
Replace the ignitor.  You will need remove the bottom plate (remove the two screws back corners).  And the disconnect the wiring from behind.  This little part will cost you approx. $100.
Nov 27, 2008 | Maytag MGR5775QDS Dual Fuel (Electric and...
Kitchen Ranges Logo
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
