Question about Interex Serial adapter
Interex Serial Monitor adaptor
I have a monitor, Sony Model: CPD 100 ES...Sony Trinitron Multiscan color computer display hooked up to a UMAX Supermax C600 (603e/240)....I can not figure out the correct code configuration on the INTEREX adaptor I have....do advise.
Christopher
Yes, the staff a Tripplite sent me the manual and I got mine to work...i could send it to your email adress.....is it adtrafiic@comcast.net
Chris
Posted on Apr 26, 2008
I have the same problem. Did you get an answer?
I need the code too.
Posted on Apr 25, 2008
Need code for interex adapter please help Tomas t.matos2@hotmail.com
MONITOR RESOLUTION SETTING
12" RGB 512x348 13467
13" RGB 640x480 66Hz 1467
PORTRAIT 640x870 23467
VGA/SVGA 640x480/800x600 60 Hz 2367
15" TILT N/A 2467
16" COLOR 832x624 1367
19" COLOR 1024x768 1267
21" COLOR 1152x870 123467
2 PG MONO 1152x870 3467
NTSC N/A 12467
NTSC/PAL N/A 12367
HI-RES 12-14" up to 640x480 1467
MULTI SCAN 14" up to 832x624 146789
MULTI SCAN 16" up to 1024x768 14679
MULTI SCAN 21" up to 1280x1024 14678
Jan 07, 2011 | Interex Serial adapter
(2000) Sony Monitor capability
Only if you need the heat from it; flatscreens of the same size use around 1/10 the power of the CRTs. Since businesses could make up the cost of the monitor in less than a year of the power savings, in 2000, it's definitely safe and wise to go flatscreen in 2008.
I used a CRT to heat sandwiches in a place with no microwaves in 1993. Otherwise they're hulking abominations that kill species.
May 11, 2008 | Gateway FPD2275W LCD Monitor
Screen always bleu
ok.. most probably the data cable of your monitor is damaged.. try to check it if the pins are still in tact.. if not, then you should replace it with new one..
Jan 20, 2008 | Sony GDM-400PS 19" CRT Monitor
Sony E530 focus (?) problem
I think it can solve with this way:
Press Menu on the front panel of the monitor. Then press OK button and go down and go to COLOR : PRESET. Press OK and go down. Press IMAGE RESTORATION.
My E530 monitor is more clearly, now.
L.E.
Sep 23, 2007 | Sony Multiscan E530 (White) 21" CRT...
Sony Multiscan E400
back light or inverter problem Dont know about repairs though.
May 20, 2007 | Sony CPD E400 19" CRT Monitor
Monitor
Are you sure this is a monitor problem? I have a user with a Mac that occasionally has the same symptoms you describe. For me I generally have to shut the computer down and physically unplug the power cord from the computer (not monitor), reattach it and restart. Let us know if that works for you.
Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
Black color displayed as green
If the owner's manual covers it, I would do a factory reset on it. I would also test the PC and video card by trying another monitor to be sure. I would check the pins for ones which are bent or broken, and check the cable for pinched spots. After that, I would say the monitor has a bad signal / video board in it.
Jan 14, 2007 | Keytec Sony Multiscan E500 21 in. CRT...
CRT monitor too bright
I have/had same problem. I have ATI Radeon display adapter and in driver settings there was adjustment for brightness. I adjusted that to minimum and now the brightness is pretty good (still little bit too bright, monitor setting 0%). Other succestions welcome...
Sep 28, 2006 | Keytec Sony Multiscan E500 21 in. CRT...
Interex serial adapter- dip switch settings for Apple G3
I couldn't find the exact Interex unit info, but cables are all standardized... so try this: http://www.belkin.com/support/download/files/F3H1381revised.pdf
Aug 22, 2006 | Interex Serial adapter
Interex Serial adapter Logo
156 people viewed this question
Top Interex Computers & Internet Experts
David Payne
David Payne
Are you an Interex Computer and Internet Expert? Answer questions, earn points and help others
