Question about Toro 60'' Com Zero Turn Lawn Mower 27hp Kohler ()
Hyd. noise when turning
This is a well used Toro Zmaster 222. I am new to the world of Zturn mowers but not mechanics. I would like to know if there is an adjustment for the hydro. the mower makes a whine similar to a noise in the power steering of a car when over extended.
  • 148 Answers
SOURCE: Need Parts/Service Manual for Toro HMR1600 mower.
Go to www.managemyhome.com and put in your model # for the manual (You can download to your computer). Also try www.searspartsdirect.com and put in you model # and you should be able to see all the parts for your mower.
Posted on May 19, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
  • 248 Answers
SOURCE: why is my toro lawn tractor eating mower deck
most likely possibility is a bad pulley
Posted on Oct 06, 2010
  • 15995 Answers
SOURCE: I have a Toro Z14-38
There is very little likelyhood that you will be able to get the manual that you want.
First TORO has proprietary information on their products.
Second is the fact that you are agreeing to only pay 4 dollars for something like that.
The only other thing that you can do is look in the US patents database to see what you can find.
Posted on Nov 27, 2010
barterjoe
  • 338 Answers
SOURCE: my toro lawn mower is hard to start in cold
This is covered by the Warranty. Take it to a local dealer like www.arcolawn.com and have the thermostat replaced.
The first generation thermostats are known for sticking.
Good luck
Joe
Posted on Feb 20, 2011
How to raise the deck of a Toro SS 5000 mower above the highest factroy setting
Hi Robert:
I'd start by looking at the mechanism with the engine off while someone else moved the height adjust lever from hi to lo several times.
There will be 2 or 3 linkages that connect the deck vertically to the height adjust mechanism. Shortening these linkages should raise the cut height. If you're lucky, there should be enough clearance to allow the linkages to be drilled so that you can simply move the mounting pins into the new holes.
Or, you could make shorter linkages.
Best of luck.
Sep 30, 2015 | Toro TimeCutter SS5000 50 in. 22HP Smart...
Toro Zmaster. Why can't the old belt be reinstalled?
Hi Daniel:
Here's a link that should get you on the right track.
https://www.google.ca/#q=toro+z+master+belt+routing
Aug 15, 2015 | Garden
Mx5050 toro zero turn mower, one drive arm more dominant than the other. With both arms all the way forward the mower slightly turns to the left. Any adjustments to correct this issue?
1st with mover off verify that both handles move same amount forward , I use a string to measure them , they both have mechanical stops that do bend and move sometimes
second locate control body valve , (thing that handles connect too) there should be a pump pressure adjust (allen key) on the side of this your gonna need to make small adjustments and try it , is difficult to do if you don't have a lift to elevate wheels of mower (but is possible without ) but takes patience
Apr 25, 2015 | Toro Garden
Where is the oil drain on a toro zmaster
It should be on the right side of engine when standing behind unit facing front. You should see the oil filter and just below that you'll see a pipe with a plastic end. Turn whichever way it will turn and pull out. it doesn't come off so don't pull or turn hard.
Aug 23, 2014 | Garden
Switch wont start engine on 34 zturn mower model 74408
check for a blown fuse in the starting circuit and check all the safety switches there will be one under the drivers seat. Is your battery charged and are the connections clean and tight
Apr 27, 2014 | Toro Garden
I have a Toro 16hp 38 in hxl with the parking brake stuck, is there a trick to this i dont know.
The snapping sound by the starter is either a bad cable connection or a bad starter. Check the cable at the starter to make sure it is tight and not corroded. If that is ok then test the starter. As for the parking brake, most mowers have a small disk with two brake pads like a disk brake on a car that is controlled by the brake/clutch pedal. Release the brake and check to see if the mechanism on the transmission is releasing. If it isn't it may need an adjustment
Jan 18, 2013 | Toro Garden
Toro 52inch zmaster shudders in drive
Hi, check the drive belt for wear and flat spots and check any idlers pulleys and arms for tight spots. regards Phil
May 29, 2012 | Toro Garden
Toro zmaster 60 doesn't seem to running on full power
dirty filters or a dirty carb with plugged jets
May 03, 2012 | Garden
Toro 60''  Com Zero Turn Lawn Mower 27hp Kohler () Logo
377 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
