Question about Nespresso Lattissima 660.R
Water button orange light appear even after descaling
  • samer_elkhal May 03, 2010
    Txs for the tip. I will try it out and will let you know if it works.
    It works. Thank you very much for the tip. It was very helpful.
I had the same problem too.
Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off.
Hope this helps you too!
Posted on May 03, 2010
Testimonial: "It works. Thank you very much for the tip. It should have been mentioned in the Nesspresso Manual. It is not even clear on Nesspresso website."
    New Friend:
Our machine's water hardness may need to be reset or your machine may need to be descaled.
By default, the machine is set to the hardest water setting, so it may prematurely alert you to descale, as indicated by the orange cappuccino light. When resetting the machine to factory settings, it automatically changes the setting to 'hard' water.
If you recently descaled the machine and are finding that the orange descaling light is still illuminated, please change the water hardness.
You may modify the water hardness setting by following these steps:
For the Lattissima Plus machine:
Begin with the machine turned off
To set the water hardness to soft water
Hold down the Latte Macchiato button while turning the machine on
Once this is done, the orange descaling indicator light will come off.
Posted on Sep 01, 2015
  • Dave Dublin
    Dave Dublin Jan 01, 2016
    Daniel Freire thank you. worked for me.
2 Suggested Answers
SOURCE: Saeco Talea Giro Plus, descaling
Try doing another rinse cycle until water tank empties. I had to do that a couple of times, then the red exclamation mark came on. Then I turned knob to off position, refilled water tank, pressed the descale button for 6 seconds, green light came back on and it did its priming.
Posted on Apr 20, 2011
NEED TO GET OUT OF THE DESCALING PROCESS. HOW CAN I DO THAT?
Descaling instructions:
  1. Press the " " button until the CACL CLEAN symbol appears. Press the " " button to start the descaling.
  2. The machine reminds you to insert the carafe and pull out the what is in there dispenser. The descaler symbol appears on the display. ...
  3. Take out the water tank. Pour the entire bottle of Saeco descaling solution in the water tank.
  4. Top up the water tank with fresh tap water to the MAX line. (Please ensure the max line is reached otherwise this will require further rinsing). Place the water tank back into the machine. ..
  5. Place a bowl underneath the milk carafe dispenser and the dispensing spout.
  6. Pull out the milk carafe dispenser to the right up to the " " icon.
  7. Press the " " button to start the descaling cycle.
  8. The machine will start dispensing the descaling solution at intervals. The bar on the display shows the progress. This takes about no moro then 25 minutes.
Sep 28, 2016 | Coffee Makers & Espresso Machines
Low steam pressure
descale the heating elements with vinnegar.
Mar 20, 2014 | Rancilio Silvia Espresso Machine
Red triangle will not stop flashing even after I descale
I have the Illy coffee maschine x7.1 and I'm trying to do the descaling (since the litle triangle sign is flashing), but power button doesn't start flashing after I push the coffee and steam button together (as indicated in the manual). Any suggestions what I should do, that the on/off button would start flashing?
Jan 25, 2014 | Illy Francis Francis X7.1 iperEspresso...
Descaling instructions bosh filtrino fast cup
It took me ages to get his to work - seems that on the THD2023GB (Black) Filtrino, you push and hold the temp. set button for 10 seconds to get he descale programme running.
Sep 30, 2012 | Bosch Thd2021gb Filtrino Fast Cup Hot...
Saeco Talea Giro Plus, descaling following instructions step by step. In step 12 the descaling light did not turn off. The warning light came on as indicated. In step 15, pressing the descaling button...
Mar 26, 2011 | Saeco Talea Giro Espresso Machine
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
How to decalcify?
1. place water and descaler solution into tank
2. remove milk frother from arm
3. place a jug under steam arm
4.hold down the button 2nd from the right next to the menu button for a few seconds.
5.descaling machine open steam knob will appear on the display
6. after descale has finished "fill water tank" will appear.
7. refill tank with clean water no descaler
8.press the button 2nd from the right as in step 4
9. rinsing machine will appear.
10. when finished"close knob"will be displayed
11. refill water tank
12. ventilate will appear on the display
13.press the hot water button and allow to run
14.ventilate will disappear,warming should be displayed.
15. job done !!!
Jan 27, 2010 | Gaggia Titanium Espresso Machine
We've descaled and the light still appears on the saeco odeo giro
Have you done as described in the manual:
Press the hot water button for
6 seconds to deactivate the
descaling light.
Jul 18, 2009 | Saeco Odea-Giro Espresso Machine
Saeco Odea Giro descaling problem
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
Jul 14, 2008 | Saeco Magic De Luxe Espresso Machine
Solis Palazzo - stuck in descale mode?
Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
Dec 11, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
Nespresso Lattissima 660.R Logo
14,523 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
