Question about HP Pavilion dv6000z Notebook
At startup my "time" needs to be reset. it always starts with the time I closed my laptop
    Guru:
  • 266 Answers
You need to change the bios battery of your laptop. then it will be fine
Posted on May 01, 2010
Go back to factory settings
First, is this to reset the configuration of the laptop to default e.g CMOS, if so there are a couple of ways,
First look for a Setup option when first turning it on, e.g press Esc or Del or F10 (search the manufacturers details - e.g HP reset and ideally the model)
Second, if you are talking hard drive, this sometimes can be done through the startup menu, normally there is an option in the startup to select the method of starting. For newer versions of Windows, press F8 a few times as the computer is starting, hopefully it will bring up a menu, if this does not work, try F9 (this is the boot device menu normally).
Other options are to use a bootable media such as a CD DVD or USB or even a Floppy Disk.
Ideally the user manual for the laptop should have instructions on how to restore the computer.
If all else fails find out where the backup battery is located and disconnected it. Sometimes you need to disconnect for a long time or jumper between some connections to switch to reset.
Feb 05, 2015 | Computers & Internet
Dell Vostro 1014 Laptop Computer is unable to start. how can I fix it?
i have laptop votro 1014 and its giving me problem that while playing oline game my laptop i becoming so slow
Aug 27, 2012 | Dell Vostro 1014 Laptop Computer
HOW TO CLOSE PROGRAMS AT STARTUP
how to close programs at startup.
1. got to START then RUN
2. click RUN, in the box type MSCONFIG.
3.click startup then uncheck the different programs.
4. click apply then restart the computer.
Mar 15, 2012 | Computers & Internet
Laptop running slow and keeps freezing on pages need to reboot system but i dont know how to restart
Hi
could you please tell us the make model and operating system that you are using
and what exactly is wrong with your laptop and is there any particular thing you are doing
on it when it freezes
also has it always been like it or only recently started freezing
many thanks
Mar 06, 2011 | Computers & Internet
My computer keeps showing rapair recommened or start up normally. what is the problem
If you close your computer without using the windows bar button, it will show the repair message on startup. You should always use the "turn off computer" in the start menu to shut down your pc.
Feb 28, 2011 | Compaq Presario CQ60-220US PC Laptop
Computer hangs some time monitor disappears some time doesnot boot
From that I don't foresee it a hardware issue, probably is software.
Some things you could try off the bat:
- On startup, open task manager [ctrl+shift+esc] > processes tab > what is the cpu at and is any one app hogging the cpu?
- Start > run > msconfig > startup tab > disable everything except for what needs to startup, which is pretty much just your internet securitymag-glass_10x10.gif apps > apply > close > restart.
- Defrag your hard drive. My computer > right click hdd > properties > tools > defragment > restart after done.
Jan 28, 2010 | HP Compaq Evo Notebook N410c
I have the slowest laptop in the world, it takes 30 minutes to boot up, and for ever to start programs and close them.. any ideas guys..
See if you can upgrade the memory (Random Access Memory), that will give you the most boost. Second thing you can do is remove any unneccesary programs that start with operating system, you can press start and type msconfig and go into the the startup tab to uncheck what you may not need during the bootup. third thing to do is organize the desktop if you have too many icons, put them into folders of each category and finaly defragment your hard drive by right clicking on the c: drive letter and going into tools, defragment, this will speed up your comp niceley.
Jun 05, 2009 | Toshiba Satellite 1415-S173 Notebook
Computer seems to turn on except for the screan.
You may have gotten a virus that started with the windows openning. Normally use ALT-F4 to shut these screens down fast. Always ensure you are running an up to date virus checker. But, your subsequent actions may have caused irrepairable damage to your OS. Do you have a virus check disk you can start with? Worst case, do you have your windows disk? You may need to re-install windows to get a clean start. If you need to do this but have data that you must not lose, try pressing F8 during startup and starting in safemode with prompt. You can retrieve data in this mode if you need to (if you don't know how, ask, or research command prompt and windows directories).
Nov 26, 2008 | Acer Aspire 5520-5908 Notebook
Every time i boot up my acer aspire 5315 laptop I always get a black screen and the computer freezes?
Please try to reboot in Safe mode after Tapping F8 Key during start.
If the option for run in safe mode not appear you need to do it again.
After then, when you login at desktop, do the following:
  1. Click on Start
  2. Open the Run window,
  3. Type msconfig, then click 'OK'.
  4. Go to the Services tab, find the 'Background Intelligent Transfer' service.
  5. Disable it, apply the changes & reboot.
Also at startup tab in msconfig, and in the Startup Tab
Disable the items which you think not necessary to come during startup.
THis will help you lot to reduce the time being taken in Startup.
Hope it will work for you.
Oct 14, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
