Question about Lexmark Wheelwriter 35 Series II Typewriter
Carriage return not working
I moved my IBM Wheelwriter 35 to another desk and now the carriage return will not work and neither will the backspace. On the display screen it shows a 1 with a up triangle and down triangle beside it. I have tried everything to get it to work again. can you tell me what will make the carriage return not work?
Thank you
Judy
  • Lexmark Master
  • 3,594 Answers
Turn off T/W and see if the carrier will move back and forth freely, if so try removing the batteries and unplugging the machine this will reset to defalt settings. CAUTION THIS WILL ALSO CLEAR YOUR MEMORY!! If the carrier is hard to move a little light oil on the shaft it slides on may cure the problem.
DickyO
Posted on Mar 25, 2008
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Ibm wheelwriter 3 troubleshoot
If it growls on return and changes the margins spray some WD40 on the silver shaft that the carrier slides on. If it thumps on return the carrier motor gear needs replaced.
DickyO
Aug 29, 2012 | IBM Wheelwriter 3 Series Ii Typewriter...
IBM Lexmark typewriter carriage return won't return to left position
Hi:
Open the top cover and locate the shiny rod that the carrier moves back and forth across. Use some WD-40 on a rag to clean it well the apply a light coating of it to the entire shaft.
Jun 21, 2012 | IBM Wheelwriter 1500 by Lexmark Electronic...
IBM Wheelwriter 6781 won't perform a full carriage
Spray some WD40 on the silver shaft that the carrier slides on. If this doesn't work Spray some on the carrier motor bearings, located under the case R. rear corner. You can access the front one from 9inside the rear you will have to fish the straw thru the case.
DickyO
Aug 04, 2011 | IBM Office Equipment & Supplies
Ibm wheelwriter won't strike. Ribbon is good. Wheel is working. Carriage is moving. Just not striking. I dusted & cleaned as well as I can but to no good.
I HAVE AN IBM WHEELWRITER 6 TYPEWRITER THAT WONT STRIKE THE LETTER. EVERYTHING ELSE WORKS? CAN YOU HELP ME FIX IT?
May 10, 2010 | Office Equipment & Supplies
Wheelwriter series II when I hit return the
The silver shaft that the carrier slide on needs a little lube WD40 works well. Also check for any deprid under the carrier that could interfere with its movement.
DickyO
Dec 26, 2009 | IBM Office Equipment & Supplies
Carriage won't return all the way to the left- almost as if a left margin has been set. Help.
if margin clear doesn't work try putting some light weight oil on the rails the carriage rides on. turn unit off, oil it and move carriage back and forth by hand then turn it on and see if that fixes it.
Nov 25, 2009 | IBM Wheelwriter 30 Typewriter
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM personal Wheelwriter 2 margins not clearing
Return to the L. margin, touch the mar rel key top key on L. of the keyboard, backspace to location where you want the L. margin, touch the L. mar key. Put some WD40 on the silver shaft that the carrier slides on.
DickyO
Jun 24, 2009 | Lexmark Wheelwriter 5 Series II Typewriter
Lexmark Wheelwriter 35 Series II Typewriter Logo
279 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
