When i turn my laptop on all the lights and the fan works but the screen dose not work
    Problem Solver:
  • 16 Answers
Check ur screen lamps and its module.
Posted on May 01, 2010
I have a Toshiba Satelite L455D S5976 with a black screen problem but the differerncece is that it does turn on the fan can be heard but it doesn't show Any thing the Screen yet it sometimes dose turn on...
I had this Problem on the Toshiba C660-1D7 Satellite But the problem was solved by Checking the Cables to the screen and checking The processor in a computer shop!
Mar 14, 2014 | Computers & Internet
Tip
How to check if you laptop screen has gone out
turn on the laptop, if fan is running and the lights that normally work are working.
shine a bright light on the screen if you see a low lit display the screen is fine.
Its either your Backlight or screen inverter which provides the power to the screen.
on Feb 24, 2017 | Acer Computers & Internet
My asus laptop has no screen display and can sense flash disks
First you thing to check is when you turn the laptop on it should make a single beep sound. if not then in means you need to replace you cpu (central processing unit} or known as a processor. thy tend to blow wen the cpu dose not get serviced. the thermal compound on the laptop cpu must be removed properly and reply st every 3-6 mouths max. If it dose beep then take a normal PC monitor and connect it to your laptop and see if that works. if it dose work then it means that the screen is busted or you should pess the screen buton on the keyboard
Nov 02, 2013 | ASUS Eee PC 1000H Laptop
My samsung r519 wont turn on. when i press the on button i here the fan going, yet the screen stay's black and only the power light comes on. what could the problem be?
Does the fan stay running? if it does! it is probably a motherboard issue, if the fan is working correctly it should wind down, and if the hard drive is working "hard drive light will flicker" hook a external monitor to the video output on the back of your laptop if you see windows boots up then it would indicate laptop screen problem, but if the fan and the power light are the only activity then the motherboard is the problem.
Dec 22, 2010 | Computers & Internet
My lp70+ projector turns on and get a weak white screen for 1 sec and then it turns off. after a min or 2 it dose the same . over and over again.. pls help :)
make sure all fans are on. you can only do this with the top off. if all fans are working then it could be a bad power supply depending on the age of the projector. also, if the colorwheel isn't spinning up, then the light will come on momentarily and then the projector will shut down.
Apr 16, 2010 | InFocus LP70+ Multimedia Projector
It dose not turn on its light keep on blinking and the screen is complete blaack
Try reseating the RAM (unscrew plastic covers on the bottom to find it), or if that doesn't work, try new RAM.
Sep 11, 2009 | Compaq Presario R3000 Notebook
MICROWAVE NOT WORKING PROPERLY
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Otherwise, it sounds like a bad door switch or door switch mount.
Aug 20, 2008 | Daewoo Microwave Ovens
Gateway laptop mx6448
Try booting from dvd drive with rescue disk
Jul 10, 2008 | Compaq Presario M2000 Notebook
Notebook Fan or Hard Drive Dead
when you leave it for a while will it start, If it dose dose the cpu fan work if so then It's not your fan, But if it shuts down after a short time it could be that it is over heating, That could be because the fan is not seated properly or heat sink is blocked
Jun 08, 2008 | Gateway MX6920 Notebook
Acer 5610
If you get the windows splash screen and it goes black that would be an indicator that your backlight is bad. Try to hookup an external Monitor to determine this. Otherwise if you get no image at all even when you connect an external monitor. You need a new HD and must relaoad your OS, and all programs! Let me know!
Nov 26, 2007 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
