Question about Boating
How to remove the lower unit to change the water pump on a yamaha 15hp, 15sg outboard boat motor, i have removed the four main bolts and disconnected the shift shaft but it wont drop down.
  • 677 Answers
SOURCE: replace water pump impellor 15hp yamaha outboard
Put the motor in neutral.On the leg of the motor there is a little side cover plate.Remove.Undo the bolts.This is the gear change linkage.At the cavitation plate,there is 4 bolts.Remove.If the lower housing does not drop,give it a soft whack with a soft hammer.When dropped,you will see the prop shaft and the gear linkage.Lower it all the way out.Its easy to work on if you put the lower skeg in a vice.Take the water pump apart BUT!!! have a look at which way the impellar blades are pointed.Grease the new impellar as you put it back in and turn it at the same time to get the nodes in properly.Heaps of grease to protect all the bolts.Makes it easier next time.Hope this helps
Posted on Nov 16, 2009
Testimonial: "cheers much appreciated "
  • 53 Answers
SOURCE: I have a 2002 ox66 Yamaha 2 stroke 250 hp std
Prop shaft. You have to remove the bearing housing cap. reference number 70. Remove the bearing housing. reference number 60. The bearing housing will need to be pulled out buy using a puller. If it was in salt water it can be difficult. Pull the prop shaft and clutch dog assembly.
Posted on Nov 18, 2009
Testimonial: "Thanks i will try."
SOURCE: how to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
Posted on Jan 13, 2010
  • 142 Answers
SOURCE: lower unit removal for johnson 225 hp outboard
Yes
Posted on May 19, 2010
Testimonial: "ill give a go in the morning thanks again"
  • 107 Answers
SOURCE: Outboard Motor Boat Bass Fishing Saltwater Base: 1990 yamaha 15 hp oil mix ratio...
100 - 1
Posted on Jul 21, 2010
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views ยท 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
How to disconnect gear shift lever on a 1996 gamefisher 15hp outboard
usually where the lower unit splits midway if you look inside you will see a couple screws or bolts remove one then it can be pulled apart.
Oct 06, 2014 | Boating
Boat impeller
Undo gearbox bolts,take off trim tab,undo bolt in trim tab cavity,disconnect speedo tube,pull off gearbox. You will see pump housing,undo 4 bolts,pull off housing exposing impeller,there maybe a clip on top of impeller depending on model,pull off clip then impeller.yamaha didn't make outboards in 75
Aug 25, 2014 | Boating
Yamaha 40 hp outboard
Look below lower mountings you will see the shift rod with along nut and a lock nut,undo long nut,do this with motor in reverse gear,some 40s have a stainless plate cover which you have to remove first
Aug 18, 2014 | Clymer Marine Maintenance and Repair...
25 hp yamaha outboard powerhead removal
Remove Cowl ,Undo Four Bolts Securing Lower Cowl,Then Undo Bolts Securing Power Head, Disconnect All Attachments To Power Head From Cowl +any Electrical Connections ,Lift Power head Out
Mar 07, 2013 | Boating
Is removing the lower end of a 15 hp older Johnson to get at the impeller as simple as removing the four bolts. Model # J15rcrm
There is also the gear change rod to undo.Look on the side of the leg,for a small plate.Inside it,is where the connecting bolts will be.Be in nuetral when you undo it and put it back together.On the water pump.Pay special attention to which way the lobes on the rubber impellar are facing.Wrong way around and you will damage the new impellar.Hope this helps
May 15, 2010 | Light Outboard Motor Boat Bass Fishing...
How do I change the water pump impeller on a mercury 7.5hp outboard?
get the kit from boat shop all it takes is four bolts and remove the lower housing.. when you put the impeller in... flex the blade the same way take a photo before you take it apart...inside get a new gasket for between the upper and lower housing too...
Apr 05, 2010 | Boating
Replace water pump impellor 15hp yamaha outboard . how to remove lower leg.
Nov 15, 2009 | Boating
I have a 1988 gamefisher outboard motor I need to put a water pump on other than taking the bolts out at the bottom is there any thing else that need to be disconnected before pulling the lower unit thanks...
yes!! there will be a cover in the back of the upper part of unit. you will need to remove this and disconnect the shifter from the lower end.
Jun 20, 2009 | Boating
Boating Logo
238 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
