The usb device didn't work - Computers & Internet
  • 10,865 Answers
Hello. When you plug in a USB device you must also download and run a disk called a driver. If you do not have a disk, you can download one. Just go to the company web site for the product and find the free downloadable driver. For example if you have a lexpro product, just google lexpro.com/drivers. Joe
please rate my answer as very helpful. thank you.
Posted on May 01, 2010
Garmin foreruuner 305 ' device not found"
Download the Garmin usb drivers from the Garmin website.
Apr 15, 2017 | Garmin Forerunner 305 GPS Receiver
Tip
How to fix ?USB device not recognized? error in windows
Are you getting a “USB device not recognized” error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn’t work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn’t work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an “Unknown Device”. 42b721d.png
So how did I finally fix the problem? Well, apparently it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
on Jul 08, 2010 | Computers & Internet
My usb device does nt working?????//
Hii
If your usb device is not damge then ther might be problem from your usb port.
If port didn't accept then you have replace it,
before replacing it please check it by reinstalling your driver and formating your system.if then also your problem remain same then need to replace.
Thanks to help you.
Aug 21, 2011 | Computers & Internet
I've have a samsung corby mate mobile. When I connect my mobile to USB, the system didn't recongise it.
connect your corby mate mobile using your usb connection
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
it might be listed as a mass storage device
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Aug 02, 2011 | Computers & Internet
I have October 2008 unit. Just newly opened the box today. I've tried on four computers today. I'm ome tonight on a Vista Gateway. When I get ready to record the 'record' lights up and...
You need to find out what's wrong before you can fix it, so:
These instructions are for WinXP (WinVista or Win7 will vary).
Login to the system as an "administrator"
START > Control Panel > System > Hardware (tab) > Device Manager (button) >
1. click VIEW (drop down menu)
2. select "Show Hidden Devices"
3. select each USB device one by one, checking each for any entries under "Conflicting Devices,"
under the "Resources" (tab). If a device has no resources tab, then just check "Device Status"
to see that Windows thinks that "This device is working properly."
What you're checking for here is resource conflicts (DMA I/O addresses). In the case of a conflict,
you'd get "device not available or being used by another application."
May 14, 2011 | ION Audio VCR 2 PC USB VHS Video to...
Hej. Yesterday, suddenly my Macbook air´s keyboard and the touchpad started not to react. I didn´t do anything, just let my laptop on the tabel for 5 min. and when I came back, it wasn´t...
when your keyboard and touchpad are not working, try to connect an usb mouse and keyboard to the laptop, just to be sure the system is responding.
if the usb devices work, you can be pretty sure there is an hardware problem. if the usb devices don't work too, maybe the system got stuck, and the best thing to do is a system reset
How to Restore MacBook Air to Factory Settings
if the usb devices work, give a try to the apple hardware test to see if it detects anything.
Using Apple Hardware Test
i had a similar problem a few years ago.. if it's an hardware problem you will need to change all the top case
MacBook Air 13 Top Case eBay
Jul 30, 2017 | Apple MacBook Air
Error occur when any usb devices is attached to my hp dv4450
how manu USBs u are connecting to the Laptop when u try to connect the USB device
Jun 08, 2009 | HP Pavilion dv4000 Notebook
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Usb ports
Go into your Device Manager (you didn`t say which OS).
Under USB you should have something like Enhanced Host controller.
That is USB2.
If you haven`t got it, your on USB1.
Normally if you only have USB1, and you plug a USB2 capable
device in, you will be told `this device could perform faster`.
Dec 26, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
