Question about Kenmore 24032\24036 Top Load Washer
Water does not enter tub - Kenmore 24032\24036 Top Load Washer
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has troubleshooting and testing procedures:
This sounds like a malfunctioning Water Inlet Valve.
I'd use the testing procedures and if the valve is defective, easily replaced.
See the following for how to release the console and cabinet to get to the valve:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d9bbe9ec76b8e8a5b2a0bd3c5685e9ea
Posted on May 01, 2010
After the washer is done, there is no water in the tub but the next day there is clear water standing in the tub
You have a defective fill valve allowing water to enter the tub while open . It will have to be replaced.
Apr 11, 2016 | Maytag MDG17MNAWW Dryer Commercial Dryer -...
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
Kenmore_665.13129K703_dishwasher clean LED flashing code 6-1, what does this indicate
Hello Gabe,
The F6 error codes means that the control board did not detect any water entering the tub.The F1 error codes means that the water in the tub did not achive the correct temperature...so the F1 code is caused by the F6, since their is not enough water the correct temp will never be achieved.The possible reasons not enough water entered the tub is,a weak inlet valve that is not fully opening to let water flow into the dishwasher
a defective part called the flow meter that is telling the machine it's full when actually their isn't hardly any water in the tub
the filter screen inside of the water inlet valve is built up w/debris and restricting water flow through it
the water line is pinched, or restricted and no or very little water is entering the dishwasher.
Good luck i hope this helps ya to fix your dishwasher,GENE
Oct 25, 2011 | Dishwashers
Water entering twist mechanism which closes K-7160 tub drain and dripping on outside of Kohler cast iron tub into basement below. Is the solution to tighten gasket on outside of tub or fix water backsplash...
If the water is entering through the overflow on the twist mech. then the gasket should be tightened and or adjusted. If possible feel around on the top of that fitting from the back side to rule out water leaking from other source, such as backsplash or faucet from escutcheons. It sounds like you have a pretty good idea of how to fix it. I hope this helps.
May 20, 2010 | Kohler CLEARFLO BATH DRAIN K-7160-TF-BV
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
No water entering tub - GE PDW9980NSS
is you water to your bath tub on the same water line as your diswasher if so both cant get water at the same time, and mabey you are useing to much water for it not to work, if you still have questions call a plumber
chris
Mar 31, 2008 | Dishwashers
Kenmore 24032\24036 Top Load Washer Logo
Sal De GO PATS
fordexpert
Ed Mac
