Question about Dell OptiPlex GX260 PC Desktop
I am going to download wireless router cd in my computer after hafl way computer show me you ethernet not found why ? i have in my computer ethernet shoket
  • 600 Answers
It might be missing a driver-check in DEVICE MANAGER
Posted on May 02, 2010
INSTALL CD
No install CD needed with valid working internet with modem. First you need to turn off your computer then connect the working hsi modem to the Netgear router with the ethernet cord (looks like a thicker telephone wire) connect the ethernet cord from the back of the modem to the first single port on the Netgear not the ports labeled 1-4. Then with another ethernet cable snap one end into one of the 4 ports available and the other end snap into your computers ethernet port. Then unplug the MODEMs power cord for 30sec plug it back in wait for modem to boot back up with all of its lights and turn the computer back on. After install is finished you can now go and download your routers firmware from Netgear. In your address bar where it reads http://.........go ahead and highlight this and backspace it all until it clears to blank. Type in 192.168.1.1 and then hit enter. A window will pop up asking for username and password. For username type in "admin" for password type in "password" this is default and will always work unless someone has changed the username and password already on your home network, in which case contact netgear support. But if it does work the you will get Negear Smart Wizard. Here is where you can click on "Setup Wizard" and follow the prompts to download latest firmware and then Finished. Close down the netgear page and happy wireless internet surfing.
Apr 25, 2010 | NetGear WGR614 Wireless Router
Linksys WRT160N will not finish installing. On the 4th step it says your ethernet cable does not appear to be connected properly. Error 321. I don't really think its the ethernet cables because i tried 2...
error 321 or 322shows that the cable is not connected to the router and the computer.
That is actually a bug in the CD. Even if the cable is connected it shows that it is not connected.
You can set up the router manually, without the CD.
Click Here for step by step solution
Nov 03, 2009 | Linksys WRT160N Wireless Router
How do i install my WIRELESS G ROUTER without the cd
you don't need to install a router on a PC. The wireless card or ethernet cable should talk to the router.
Sep 21, 2009 | D-Link DIR-300 Wireless Router
No setup cd for the Linksys WRK54G Router
hi! you can still setup your router even there is no setup cd. connect your ethernet cable to port 1 of the router and the other end to the ethernet port of the computer..press the reset button on the back of the router for 10sec.. unplug the power of the router for 15secs and then plug it back in.. pull up your internet brower and type in to the url: 192.168.1.1 and it will prompt the username and password.. by default the username is admin and the password is blank - means-leave it blank.. then it will show the setup page of the router....
Aug 07, 2009 | Computers & Internet
Wireless network using usb modem
First thing that you have to do is to check if the wireless light on your linksys wrt150N is lit. If it is, then that means that it is emitting wireless signal so you can connect wirelessly.
Then, install your verizon usb mobile broadband card on your desktop. When you plug it to the usb port, a pop up balloon would show on your page which would say FOUND NEW HARDWARE. you could click on it and choose the CD-drive to install OR you can run the cd and have it install on itself.
After installing the usb, try to connect to your wireless network. Start > Connect to > and then click on the name of your wireless network.
Apr 08, 2009 | Linksys Wireless-N WRT150N Router
Cannot finish installing
It means you have to plug in your computer to the router through a ethernet cord. Most computers have one, and on the back of thats router has 4 ehternet female ports. Plug it in, and run it again.
Dec 02, 2008 | Linksys Wireless-G WRT54G Router
No Installation CD for Wireless-G Notebook Adapter
Hello! It is possible to install it without the CD< but not easily >You will need to, On a separate computer, Go to Linksys.com and download the drivers, then just burn them to a CD< or Put them on a flash drive, and install it on the laptop. Unless the laptop has a Ethernet port, then just connected the computer to the linksys router VIA Ethernet to download the drivers.
Nov 24, 2008 | Linksys Wireless-G WRT54G Router
Toshiba Satellite ethernet port disappeared...
I think you have answered your own problem, your wireless has possibly been zapped.
To test your ethernet adapter on your laptop connect it to a network hub, check the hub and see if you have a link light on the hub and or laptop..
To test your wireless router, connect it to a known working computer with a network card and check the router configuration, using the browser, if you cannot access it then its zapped.
Jul 08, 2008 | Toshiba Satellite A105 Notebook
Router
Yea, if you have your initial run CD, use that but here is how you do it.
MODEM-ROUTER-COMPUTER
I
Other wireless devices.
You plug the ethernet cable going from the modem into the plug on the router labeled internet. Then give it a cable from ethernet slot 1 to the computer. You should be good 2 go.
May 23, 2008 | Linksys Wireless-G Broadband Router
Dell OptiPlex GX260 PC Desktop Logo
21 people viewed this question
Alun Cox
