Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do you adjust chain oiler,increase or decrease amount of oil
  • 1 more comment
  • trucking98 May 01, 2010
    sorry not my saw so cannot give s/n but belieave it to be fairly new 145 or about that size about same size as older 55
  • dontbother10
    dontbother10 May 11, 2010
    Not 145 no 145 chainsaws. I need the correct information to help you.
  • dontbother10
    On some model Huskys you cannot. How about a model and serial number Needed to find your IPL). Reply below please.
    President:
  • 2,220 Answers
Did you get it Lowes? Most new homeowner class chainsaws have no oiler adjustment (bad idea! lots of problems). If it does there is a mention in the OM under or near bar maintenance.
Intermediate class saws often have a 3 position oiler. The professional grades have fully adjustable oilers.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 02, 2010
CSP4518 model. There is way too much oil coming onto the saw and bar in use and I can't find anything in the users manual. Any tips?
check that the jet where the oil comes onto the bar/chain has not being plucked out during operation
use chain bar oil , not engine oil
Apr 12, 2015 | Homelite Garden
What causes to much oil for the chain to come out when cutting
Sometimes people opt to use regular multi viscosity engine oil in their oiler and because it automatically thins when heated, the oil pump has a tendency to pump more. Actual bar oil, though expensive, is specially formulated to 'stick' to the bar slot and to the chain as the speed of the chain increases. It also thins to a degree when heated by the natural operation of the muffler, but not nearly as much as engine oil.
Usually an oil pump is designed and adjusted in the factory to pump just enough to have a bit of excess in the tank when the gas tank runs out. The older pro series saws usually had an external adjustment to increase or decrease oil flow. That adjustment was located on the bottom of the saw directly under (or near) the sprocket. Its markings are a + and a - for increasing or decreasing.
Mar 12, 2015 | Garden
How to stop sawdust from coming into the carburetor section and how to adjust the chain oiler. chain seems dry.
Check to ensure the oil opening on the side of the saw housing is not plugged as well as the matching oil groove in the guide bar first. Turn the saw upside down and see if there is a + and a - sign near the sprocket on the bottom. If so, turning towards the + increases flow. Most new small saws oilers are non-adjustable.
Feb 23, 2015 | Stihl GUIDE BAR 16 in STHIL CHAINS
Chain oiler does not seem to be putting out enough oil,what can i do to increase the flow?
This model does not have an adjustable oiler. If the ports are clean and the pickup is clean, you may need to replace the pump. This is generally an inexpensive repair.
Feb 20, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Chain oiler. turn up?
Release the chain brake and remove the bar and chain. Clean the engine side case where the bar fits to, then start the engine and observe whether oil oozes out of the port. If ok, clean the small oil passages in the drive end of the bar--they run from the large holes out to the chain groove an each edge. Check the oiling by running the saw tip at speed near some cardboard--it should throw off a thin line of oil. Look for an adjustment screw head set into the rear-underside of the case near the chain return area. Turn CW to decrease oil volume. Hope this helps!
Dec 11, 2010 | Husqvarna 450 e-series 18" Chain Saw
To much oil comes out of the chain oiler
Look for an oil volume adjustment screw located near the lower chain run, but on the main case rear or maybe underneath the case in the same area. Turn the screw CW to decrease flow. Remove the bar and chain to make sure the small oil passages in the drive end of the bar are not plugged. When everything is back together, run the saw tip near some cardboard at speed for a moment or two. It should throw off a thin line of oil onto the board. Hope this helps!
Jul 01, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Auto oiler not working
Remove the bar cover. Remove the chain and bar. Behind the bar you will see a set of 4 or 5 small square openings. This is the auto oiler. Make sure they are not obstructed with gunk. There is also an adjustment to increase the oil flow to the bar. It is a small screw and will be marked with a + on one side and a - on the other. You can adjust it to run from 5 (minimum) to 15ml (maximum) per minute. Never use old motor oil or 2 cycle oil in yo
May 22, 2010 | Husqvarna Chain Saw 20" Bar
How do you make the chain oiler spit out more oil? Its a husqvarna 450.
There is an oil-volume adjustment screw located near the chain return area either in back, or just under the case. Turn it CCW to increase volume. Hope this helps!
May 12, 2010 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Apr 10, 2009 | Garden
Need help with 66 triumph 650 bonneville
After these bikes have set for a period of time the oil in the oil tank drains to the lower end of the engine and when started after sitting the oil is usually forced out of the vents for crankcase; which on many of these bikes is through the primary and possibly to the chain oiler etc. Usually after running for a few minutes the oil is back in the oil tank and over supply to the oiler stops! Could possibly soak the clutch plates if it filled primary case also. Be sure and check oil level in tank?! If you added oil before starting it will now be overfilled after starting. This is common problem and will mend it self usually. Does make a mess in the garage toooooooo! Jesse "Leroy" Graves
Dec 21, 2008 | Triumph Bonneville Motorcycles
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
531 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
