Question about Dell Wireless Keyboard Optical Mouse w0147
Mouse pointer is not on screen. Dell Studio 19
  • 186 Answers
Go to control panel check mouse pointers
Posted on May 01, 2010
Gateway HDMI laptop T series charger output 19 vgets v.hotbut works . burser pointer starts jumping frm place to place on screen dificult to control ?
run it in battery to see if fixes cursor problem
also try a different mouse see if that makes the cursor move correctly
this way you see if its the mouse or power supply
might also a touch pad problem anything that controls the cursor
May 07, 2015 | Gateway Computers & Internet
Help! My Dell Inspiron Desktop (Windows 7) went into sleep mode, I shook the mouse to use it and got a black screen with just the mouse pointer. I powered down & back up, got the Dell screen and the...
My guide might help you, it's worth a try, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Sounds like a windows error though, some how the installation may have been corrupted. I suggest performing a virus scan on a test PC. An alternative is to take it in to a computer technician.
Thanking you
Happy testing
damnor01
Nov 15, 2010 | Computers & Internet
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
Drifting mouse pointer
Go to Control Panel - Mouse - Pointer Options - and uncheck 'Enhance pointer precision'.
Feb 28, 2010 | Dell Precision M60 Notebook
The mouse touchpad on my Studio 1569 is not very sensitive. I can hardly get the mouse to move and I can't find where to adjust. The OS is windows 7.
Windows 7 loves to hide these things. unfortunately, this is one that Microsoft forgot to make hard to find..
Start -> Control Panel -> Mouse -> /Pointer Options\ and change the level as needed...
If the mouse won't reach it fast enough, use [Tab] to jump to the scroller, then use the left and right arrows to change it..
Depending on how dirty the corners of the touchpad are, they may need to be cleaned. DO NOT SPRAY IT WITH CLEANER. Find a cloth, apply cleaning solution to cloth lightly, then wipe area, and dry. anything stuck in the corners will degrade the mouse's response.
If you have ever opened the case, be sure to push the wire back in carefully and as far as it was designed to go, otherwise bad connections (resistance) will not allow it to be used fully.
Good luck.
(Keep in mind, I did not just give you permission to open your laptop. Very delicate on the inside, and painful if you have never done it before.)
Feb 25, 2010 | Dell Studio 15 Laptop
When I move my finger along the Touchpad it does not do what it's supposed. The pointer either doesn't move or responds in a delayed fashion. I have a dell studio 1735 laptop. Thanks.
Try updating first the touchpad drivers from the support website www.support.dell.com . If updating wont fix the problem try adjusting the mouse sensitivity to your preferred settings on control panel. Hope this helps
Dec 05, 2009 | Dell F3534 Touchpad
Mouse does not turn off
weird havent herd of that before have you tried to replace the batterys while everything is off? ie comp and mouse dock, even unplug the dock if it is not usb powered it might help, i am guessing
Jun 29, 2009 | Dell Studio Hybrid Desktop Computer
Black screen with mouse pointer after lcd screen repair
If you can see a mouse pointer clearly, you have a software issue especally if see a post..
Apr 20, 2009 | Dell Inspiron 1525 Notebook
Dell optic Mouse
See if this helps at all: turn off the Enhance pointer precision feature: 1. Click Start, click Run, type control mouse, and then click OK. 2. Click the Pointer Options tab, click to clear the Enhance pointer precision check box, and then click OK.
Sep 28, 2007 | Dell U0636 Mouse
Dell Wireless Keyboard Optical Mouse w0147 Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
