Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Tried resetting tried canceling,still will not wash
Can here the washer running but green keeps coming back on
    President:
  • 949 Answers
If the green clean light continues to come on and flash there is a failure in the heat circuit. I have put together some things to check. Take a look at this link and see if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Posted on May 01, 2010
My LG top load washer keeps stopping mid cycle- what could be wrong?
First rule out the simple points like to clean the filter for fluff or coins that may be interfering with pump. Secondly is the pump itself.
Jan 09, 2018 | LG Washing Machines
Fridgeadare front loader lights keep coming on. I hit cancel and they come back on in a minute or so
Good Afternoon Rosemary, thank you for your question. Let's try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer lights continue to blink/flash. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Aug 27, 2013 | Frigidaire ATF6000ES Front Load Washer
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    FH appears
  • 2
  • 3
  • 4
  • 5
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    I started washer cycle forgetting that our water was turned off. A few minutes later I hear it beeping of course. I tried to cancel cycle but it just keeps trying to drain non-existent water and the door...
    pull off the back panel and on the bottom right is a white panel. take off the panel and disconnect the power wires to the cpu and plug in. unplug and reconnect the wires to the cpu in the circuit board. this is a hard reboot.
    Feb 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Green light on kenmore dishwasher is flashing
    I actually had to change the steps a little and this is what I did:
    press heated dry
    press normal wash
    press heated dry again
    press normal wash again
    wait a few seconds
    all the lights should come on
    press cancel (should hear pump)
    hit cancel again
    Started a cycle and began washing.....Thx
    Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
    Washing machine
    Pressing and holding the two centre buttons ie on/off and start/cancel together for a few seconds causes the machine to run in 'test' mode. Doing the same again puts it back to normal wash.
    I nearly called an engineer once because my daughter causes it all of the time!
    Sep 28, 2008 | Hotpoint Ultima WF860 Front Load Washer
    Help with whirlpool awm 8103/1
    Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
    http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
    If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
    http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
    I hope this helps you. If you require additional assistance, please let me know.
    Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
    Hotpoint wf 250 aquaries
    try changing your water valve this should sort problem
    Jun 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
    Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
    62 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    vince
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
