Question about Magic Chef (CSD2610KRW) Top Freezer Refrigerator
Refrigerator not making ice or getting cold
Won't make ice ,varily get cold ,how to solve this problem with my magic chef refrigerator
  • Magic Chef Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly
Your symtom comment that it is barely getting cold leads me to think the problem is in the automatic defrosting of the refrigerator.
Your unit has a mechanical defrost timer. It is item 6 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5168518&diagram_id=1349648#d1349648
If you look at the panel all you will see of the defrost timer is 2 raised / tapered tabs that would only allow you to rotate those tabs in one direction.
Use a flat bladed screwdriver with a good blade or a rather wide flat ended kitchen utensil to rotate the defrost time until the compressor shuts off. That is the beginning of the defrost cycle. Leave the unit sit for about 1 hour and see if it performed the defrost cycle and restarted the compressor.
If the compressor did not restart.... there are other components of the defrost circuit that have failed.
Those components can be any one of the following:
1. The defrost timer itself.
2. The 60 deg bi-metal thermostat
3. The defrost heating element
4. A wiring problem to any of the above
If the unit did not defrost at all.... what you can do is perform a manual defrost by unplugging the unit, emptying the contents of the freezeer section and placing a fan blowing into the freezer section for just over 2 hours. This WILL make a WATER MESS so be ready to tend to the drips with rags and a mop.
After that 2 hour manual defrost reload the freezer and plug the unit back in. The temps should return to normal in about 4 hours.
If the manual defrosting corrects your no ice and warm fresh food problem then you for sure have an automatic defrosting problem.
One thing to note is.... if the evaporator fan in the freezer compartment is not running you will have a warm fresh food compartment and no ice. If the fan is NOT running and the compressor IS running the evaporator fan has failed.
The wiring diagram for your Refrigerator can be found here:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1326763&pkw_=basket&model_id=5168518&NewWindow=1
Thanks for using FixYa,
Kelly
Posted on May 01, 2010
My Magic chef refrigerator/freezer has a problem with the refrigerator part getting warm. I tried shutting it off and letting it set for 24 hrs and that worked a couple of times, but now it just doesn't...
sounds like your refir has an interior circulation fan which is not running. If not the vent to allow cold air to recirculate is closed. Could be the freezer is icing up and defrosting it is helping somewhat.
Feb 03, 2011 | Magic Chef Refrigerators
Ice formation in Magic Chef Top Freezer Refrigerator
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | Magic Chef CTB1821AR Top Freezer...
Magic chef side by side not keeping cool around 50 deg.and freezer not makeing ice cubs and not realy cooling also
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
arha46w
Jul 01, 2010 | Magic Chef (CSD2610KRW) Top Freezer...
Ice maker does not work
magic chef mini fridge stops colding
mod#MCBR171W 1.7cu ft
Jun 30, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Dec 27, 2008 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Aug 27, 2008 | Magic Chef Refrigerators
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
165 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
