Question about Keurig Platinum B70 Coffee Maker
I not get coffee out of my machine
I turn on my coffee machine, I hear it take in the water from the cyclinder and the screen tell me it brewing and I hear it heat up but I don't get any thing out?
My aunt has a Keurig and I just bought one for my mother and one for me because we like the coffee so much! Her coffeemaker was giving her trouble - not pumping water through. She tried every cleaning method recommended by Keurig, then she took a can of compressed air. like the kind you use to clean out computers. She put it over the opening as tight as she could as she did not have the "straw" on her can. The "clog" in the water tube dislodged and water sprayed out. (Do this when the machine is cool as hot water can burn!) Her Keurig is now working great!
Posted on May 03, 2010
    Problem Solver:
  • 8 Answers
I can only go from my problem where you select brew and nothing really happens...
this was a bad connection in the unit... I went into the unit and reseated the connectors. there is an electrical panel that all of the low voltage motors,sensors, and valves plug into. I used a pair of needle nose pliers to pull the connectors out... and back in.. and the unit worked...
Posted on May 02, 2010
I have a Saeco Incanto S-class sirius machine. Message displayed, "Brew Group Blocked", so I purchased a new Brew Group Unit, when I installed it, got the same message. when turned on, I can...
Brew group blocked is normally displayed when there is no water flowing through the brew unit. Remove the brew unit and use a small screwdriver(make sure machine is off and cooled), then gently lift up on cross section fitting on white plastic valve inside the machine, if water flows out it works, now we will plug in machine keep brew unit out and turn it on and press fitting in again, if water flows and pump kicks in and water flows out from valve and not under machine you are good, The coffee grind might be too fine and needs to be adjusted to coarser.
Jun 28, 2011 | Saeco Incanto Sirius Fully Automatic...
My Saeco Incanto Sirius grinds the beans but does not pump out the coffee into the cup
If you already tried the previous suggestion (grind at the most coarse setting) and you still get no water, it may be the SBS brew valve.
As a test, run a blank shot by telling the machine you are going to add preground coffee but don't add any coffee. When you start your shot you should get plain water (probably tea colored as it flushes out some old coffee left behind from previous brews).
If you still get no water, then it is either your brew filter screen is plugged or the SBS brew valve is plugged.
Remove the filter screen and hold it to the light, can you see through all or most of the tiny holes? If not, soak it in a good coffee detergent and scrub it with a toothbrush until the holes are clean (DO NOT USE A NEEDLE TO CLEAN THE HOLES).
If it is the SBS brew valve, you can open it fairly easily to clean it but there are a couple of tiny parts and a spring so be careful.
And final thoughts - the SBS brew valve can be defective - I've had some that were too tight and simply wouldn't allow any water to flow at all. But since yours was working before, it probably just needs cleaning.
Jun 12, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Apr 14, 2010 | Saeco Odea Giro Plus Coffee Maker
My coffee machine won't brew. i put water and coffee in the machine, turn it on, and although it tells me it's brewing, it fails to brew.
Without opening the item up you would not be able to cure it. Unplug it, take cover off and have a look to see if you can see a blockage or a reset betton for the element.If not you may want to replace it or get your item repair via a engineer.
Dec 05, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Our Rancilio Silvia is producing really bad tasting coffee of late...my husband thinks that it is old water but I think it may have something to do with the fact that it has been leaking from the steam...
Hi
More than likely its you brew head screen. Coffee will build up on the top surface and turn rancid after awhile. Remove the screen(its either a screw or bolt that holds it on). I like to remove everything and turn the machine upside down on a towel. That way I can see what I am doing. Clean everything even around the brew head gasket. This gasket needs to changed every year for best sealing of the portafilter. Buy 2 because they always fail on Friday when you have a party on Saturday.
Soak you brew head screen in hot water with a pinch of automatic dish washing detergent or espresso machine cleaner. Use a tooth brush to remove the crusty burnt on coffee residue or just buy a new screen. Clean this screen every 6 months because they should last the life of the machine.
Nov 13, 2009 | Rancilio Silvia Espresso Machine
I can hearing brewing noise, but no water filling the carafe
IF UNIT IT`S MORE THAN 4-5YRS BUY A NEW MODEL, U SAVE SOME MONEY FOR THE NEXT 5YRS
Aug 19, 2009 | Coffee Makers & Espresso Machines
No coffee coming out, just hot water
Two questions:
1- Is the coffee grounds wet or dry?
2- Does the spout drip water when the machine is just heating up?
If the grounds are dry then the brew chamber is not getting any water. Turn machine off, let it cool down, then remove brew unit. Behind the brew unit there is a white valve with 2 red o-rings(sometimes black), if you look closely there is a small lever between the o-rings, get a small screwdriver and gently lift lever and spring, if water came out then the problem is in the brew unit, unscrew the stainless steel screen which is under the large red O-ring on the brew unit and clean, also make sure the tube on the unit is clear.
If the hot water spout is not dripping when the machine is heating up then you're good.
May 12, 2009 | Coffee Makers & Espresso Machines
Can't Prime Water Circuit
Hi You need to switch Steam ON so it heats up and then turn Steam button OFF (no light) and then turn steamer knob counter clockwise you will hear the pump start up and then water will stream out. This is when it's primed. Turn steamer clock wise to close. You must do this everytime you use the steamer.
Dec 06, 2008 | Saeco VIA Venezia
Keurig Platinum B70 Coffee Maker Logo
546 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
