Question about Dishwashers
I have a Whirlpool GU2600XTPS7 dishwasher - long washing time
I have a Whirlpool GU2600XTPS7 dishwasher, and of recent it seems to be washing for longer and longer - last night it was for almost 2 hours and there wasn't a lot of dirty dishes in it.
thanks
    President:
  • 949 Answers
You could have a couple things going on here. It could be either related to water temperature, build up in the sensor area or poor washing.
If the dishes are coming clean then you can discount the poor washing.
1st thing to try is clean out the dishwasher, a build up or residue can form on the sensors in the bottom and they can be fooled into thinking the water is cloudier or cooler than normal and it would take longer to heat the water and wash. Here is a link to some instructions I put together on how to clean it out.
Clean Out Procedures
2nd thing to try would be to run the hot water in the kitchen sink until it is hot before you start the dishwasher. By doing this the dishwasher will not have to slow down and pause while it is heating the water enough to clean the dishes
Posted on May 01, 2010
Our Whirlpool dishwasher is not cycling properly. After resetting (Wash + Hot Dry 3 times) I get an "error code?" d3 07. What does that mean?
Is this hooked up to a insta hot under the sink? if so, the insta hot could be bad or the line coming from it could be clog meaning that there's no water coming into the dishwasher .
Oct 20, 2014 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
Hello ! We have a Whirlpool "Quiet Wash Plus" dishwasher that is approx 12yrs old. It has performed exceptional over this time, but notice recently it does not get the dishes as clean as before....
Is the water level ok? Check your water temp into the tub. It needs to be a minimum 120 degrees. Check for plugged spray arms. Do they turn freely? Does dishwasher drain completely?
Sep 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The heating / steam cleaning cycle does not seems to be complete
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
ll
Jul 16, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
The lights in the front turn on but not my dishwasher whirlpool model GU2600XTPS7
you could either have a bad door switch. check for continuty on the switches
Mar 26, 2010 | Whirlpool Dishwashers
Whirlpool QP II dishwasher - Not draining
I had the same problem... I jiggled the washing machine.. the discharge hose seemed to be clogged.
Oct 21, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
Oct 09, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool DU1100XTPS dishwasher leaking from front door panel
Hi karen_kinzer,
I'm Harvey the Master Plumber.
The d/w was a recent purchase?
Then my advise to you is don't worry about it! The unit should be under warranty. It's time to make the call. Let the warranty repairman worry about it. If he can't fix it, he has the authority to condemn it and you'll get a new one. Anyway, this is one problem you should not have to worry about.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
Dishwashers Logo
113 people viewed this question
Top Dishwashers Experts
