Question about Dishwashers
Miele model G696-60 The red light dispalying "Entre" is falshing and the dish washer is not working and there is water inside.
  • p_shemirani May 01, 2010
    Please note the writting on the Machine is in french and German so the light is falshing next to the words Zulauf/Entree. The Machine started working for a few minutes and then it stopped with this light falshing, there is now some water inside the machine.
    Thanks.
  • Rick Ead
    Rick Ead May 11, 2010
    does it give you any other error code usually entre means soething with door maybe the switch on the door if the door is telling control that it is open it wont work
SOURCE: miele dish washer
I had the same problem only I couldn't get it to go at all. The problem was a bad motor/pump assembly (VERY EXPENSIVE). The bottom inside the dishwasher filled with water, so the intake interlock wouldn't allow new water to go in. I think I am going to throw my 4 year old, $1000 dishwasher out and buy a new one at Sears. Can't believe it is so poorly made.
Posted on Apr 30, 2008
SolutionGuy
  • 331 Answers
SOURCE: disher washer not getting any water??
Hi Harris,
Without a model number, I can't be 100% certain... but it sounds like the flood/safety float is stuck in the ""flood" position. It works by rising and falling with the water level in the tub. If there's too much water, the float will trip a switch and kill power to the inlet valve.
Open the door and remove the lower rack. You should see it right there in front inside the tub. Just lift it and drop it several times to clear it. (It's gotta be all the way down for water to get to the dishwasher)
Now try the dishwasher. Did it get water? If so, please rate this solution. If not write back and we'll go a little deeper.
Tracy
Posted on Mar 27, 2009
SOURCE: the miele g527 dish washer is not getting enough
I have just had the same issue. It actually turned out to be a very simple fix. The water inlet pipe has a very small copper filter that must have blocked up with age. I simply removed the filter and replaced it with a new one off a washing machine and the problem was instantly solved.
Posted on Jun 18, 2010
  • 177 Answers
SOURCE: Hi I have a Miele dish washer, that flashes red
I have found the manual for you. Go here and enter the model number (you don't need the serial) It will give you a pdf of the manual. I hope it helps! Please rate me! :) http://mieleprofessional.ca/ca/prof/products/manuals.aspx
Posted on Jul 17, 2010
news775
  • 699 Answers
SOURCE: hi the red light on
It could be a simple thing like the intake filters need to be cleaned.
There is 1 or 2.
Pull out dishwasher.
Turn off the water supply and undo the hose at the tap and see if there is a filter in there and clean it.
Also undo the hose at machine end and look where the hose fits and see if there is also a filter on the inside of the pertruding thread. Clean out this filter.
make sure hose is tight both ends and push machine back in making sure hose is not kinked.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 15, 2011
Miele G1182 dishwasher not working
Any water comming in to the dish washer area?? If not check the inlet water valve, they get clogged with sand from the water supply. They can also clog open, in which case the dishwasher will flood the floor with water afer about 3 to 4 imins of use.
Dec 19, 2012 | Miele Dishwashers
The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Jul 20, 2011 | Miele Dishwashers
Hi the red light on my Miele premium plus dish washer is on after the machine is done. It indicates water intake. Is this an easy fix?
There is 1 or 2.
Many thanks
Feb 15, 2011 | Miele Dishwashers
Hi I have a Miele dish washer, that flashes red light next intake/drain and stops working. I do not have the manual. Could you please assist me with it? Thank you.
Jul 17, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Wate rleak Miele premier 300
I have exactly the same problem with my new Miele washer dryer - and my kitchen is soaking wet. Have you found a solution ?
Jul 28, 2008 | Miele Novotronic Premier 500 Front Load...
Miele dish washer
I have a miele G 643 SCVI Ingognito the re-0cccurring prob is the the drain/intake light comes on quite frequently I have to cylcle the on/off switch twice to clear the fault. I have check the drain line several time w/o any obvious findings what's next
Feb 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Miele dishwasher film and crust on the inside-
Hard water has this "crust" which are minerals floating around that ionically attach to everything. Some machines from Miele have a water softener inside the machine. Special dishwasher softener Salt is added that cleans minerals off Xeolite beads. When cleaned they attract mineral ions. If you don't use the salt then the beads fill up on minerals until they can't hold any more minerals. The salt is used in the regeneration cycle. It washes the mineral ions off the xeloite replacing them with salt ions. As new water enters the machine mineral ions slowly knock off the salt ions and attach themselves to the beads again. This whole process keeps the crust off the dishes and the walls of the machine.
Use a dishwasher cleaner that removes scale. And if you don't have a salt light on your Miele you can instead purchase soap tablets that contain water softener built in. Miele dishwasher tablets have it. You can order them online or call Miele.
Dec 17, 2007 | Miele 23 in. Novotronic G841 Built-In...
Problem in dish washer
DAER SIR ,
THIS IS MANITOWOC EC50A MODEL ICE CUBE MACHINE.SIR, MACHINE WORKING AFTER 1hr MACHINE WATER FLOW IS LOW ,
AT THIS TIME SOLENOID VALVE NOT ON POSSITION PLEASE REPLY FOR A PERFECT SOLUTION
BY
JOTTIN FRANCIS
KERALA
Dec 04, 2007 | Miele Dishwashers
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
