Question about Nokia E63 Cell Phone
Nokia e63 won't switch on or charge
I've had my nokia for 3 months now and last week i charged my phone and the phone lost its charge within the same day and turned off. when i got back home i went to charge it and there was no indication that it was charging (in fact it didn't charge at all). so i went to the nokia care centre and bought a new battery, it worked and it showed the charging sign. I was told to charge it from 6 to 8 hours since its a new battery but when i unplugged it i was still left with 1 bar of charge, and then it switched off again and now i cannot turn it on or charge it. Any solutions please??
    Genius:
  • 1,416 Answers
this have nothing to do with your phone battery and the phone charger
from your statement what you need to do to fix up the problem is that you have to make a change of your phone charging port this is well the problem is from
the charging port bad
dole it will give a sign that it charging but the same time it will discharge the power and this can cause a damage on the battery bass on constant charging
what you need to do is that you are to make a change or replace the port with a better one
if you can not do the fix up your self then you will have to take it to a very good phone work shop around you to do the fixing then your phone will work fine again
thank you .
Posted on May 01, 2010
How do i know if my nokia E63 is charging
my e63 nokia is have charging problem. If i plug it light it will show charging and immediately notcharging. what can i do pls?
Aug 01, 2012 | Nokia E63 Cell Phone
My 5 WEEK OLD nokia e63 won't turn on. the d-pad lights up along with the screen (black) but it won't do anything else... HELP!
Before you go to NOKIA CARE please check the battery.It may be discharge to 2.8v. If the volt is less than the phone wont start up.I've experience this kind of problem many times and I solved it by backing up the battery by eliminator.So you can try it or if you have other battery which can insert/in same type try to put it and start.Thanks for visiting fixya
Aug 26, 2011 | Nokia E63 Cell Phone
My Nokia E63 is not turning on, I've changed the battery, charged it with a desktop charger, on other phones it will on but on my e63, I won't just turn on. what am I to do.
PHONE IS DEAD WON'T COME ON
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jul 05, 2011 | Nokia E63 Cell Phone
My nokia e63 is not switching on after it was kept off for a month
if it charges charge it for 4 hours or better by another battery and charge for 3 hours it should switch on
Mar 23, 2011 | Nokia E63 Cell Phone
Hi friends, I have Nokia E63 mobile phone which is 3 months old. From last week it repeatedly gives "Phone memory full" message. I don't know what is that mean. Anyone else having the same problem. Please...
This is because the phone memory or the memory card is almost full up to its maximum capacity. This message will automatically vanish if you clear some useless data from the memory and make some space "free".
Cheers. Thank You.
Oct 15, 2010 | Nokia E63 Cell Phone
Lost my NOKIA E63
you can get imei tracking software in google search
Jul 17, 2009 | Nokia 7610
Nokia E63 Cell Phone Logo
1,267 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
